lathe drilled hole not concentric - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
  1. #21
    Aug 2002
    West Unity, Ohio
    25,097
    5345
    7841
    Quote Originally Posted by Delw View Post
    This
    but i'd be more concerned on how he is checking it. I am guessing Calipers
    I can tell the diff between .432 and .438 with a calipers.
    ABS value not a concern.
    Calipers could have .010 worn tips and been dropped 2 yrs ago and be .025 off.
    As long as they repeat good, we are looking for a differential value. (Incr?)
    Crickey - Robert snucked in there ....
    Think Snow Eh!
    Ox
  2. Likes Bobw liked this post
  3. #22
    Jan 2019
    Arizona
    553
    39
    190
    Quote Originally Posted by Bobw View Post
    What is wrong with calipers to make sure he is within .010" of center, so that the part works.
    Are you one of those people that build a fixture for everything and refuse to use a vise?
    Nothing wrong with calipers I never said that. he is checking less than .010
    it pretty hard to use a vise on a Lathe
    as far as fixtures and vise's this is a lathe part he chucked it in a chuck and spun it.
    I think I would be checking with a V-block and a indicator to see what the runout is, but then again thats just me
  4. #23
    Jan 2019
    Arizona
    553
    39
    190
    Think Snow Eh!
    Ox
    I agree with that
  5. Likes Ox liked this post
  6. #24
    Dec 2008
    New York
    10,037
    2610
    many machines need either a mechanical alignment adjustment
    or a electronic grid shift adjustment (cause distance from zero return has changed)
    some places check parts and if a problem calibrate or align machine
    other places check monthly
    other places check daily
    i have seen many a cnc lathe or mill needing adjustment. for some its a maintenance people do it and for other shops the operators do it first and if for some reason they have a problem then they call maintenance. sometimes the adjustment is explained in the maintenance manuals and not the operator manuals
    saw where a M0 was added to a program to check a part at a spot where part often failed inspection. then operator often saw the problem quickly rather than part go to inspection and find out days or weeks later.
    kind of a weakness with mazak conversational in sure you can add a M0 but not so easy to leave a comment in the program. some use a desktop computer with a setup sheet procedure or work instruction and there the M0 is explained what for
    i have seen many a part on a cnc lathe where the hole in center of part is not on center. its actually a fairly common error. amounts can vary. even with soft jaws just bored if chuck dirty you also get random chucking error or chucking runout on top of machine alignment errors from the rest of machine. obviously if thin walled part and your chucking pressure too high you can squeeze part triangular distortion and when unchucked you can see or measure the triangular distortion if 3 jaw part. chucking pressure distortion obviously more a problem with tight tolerance thin walled parts
    i have also seen where machine grid shift adjusted to .0002" and when zero return or homing done grid shift was off again.
    when machine repeatability not happening often its a call maintenance thing. it could be something worn out mechanically or a electronic scale or encoder is dirty (coolant or oil is common). a sign you got a problem is when grid shift is adjusted more than one or two increments. after all why would you need more than a fine adjustment.
  7. #25
    Jan 2006
    New York
    1,597
    681
    781
    It's a frikin hole in the center of a turned part.
    spot drill, then drill. problem solved (and the op got all the the info he needed to get him going in the right direction)
    summa you guys really know how to beat a dead horse.
    man, how do you guys deal with "real" problems
  8. Likes mc3608, Derek Smalls liked this post
  9. #26
    Feb 2005
    9,018
    13662
    10663
    Quote Originally Posted by chip_maker View Post
    alcohol...
  10. #27
    Jan 2006
    New York
    1,597
    681
    781
    alcohol...
    That's one way lathe drilled hole not concentric.
    Sent from my SM-G930V using Tapatalk
  11. #28
    May 2008
    Minnesota
    684
    352
    232
    I got a chance to work on this again this morning. Put in a 120 degree 1/4" shank solid carbide spot drill and that is ending up perfectly on size and perfectly (for as well as I can measure) concentric.
    My initial reason for trying to avoid spotting is that I only have room for a single drilling tool available in the setup. So now I am going to be spending some money with Maritool for a few more tool holders and will have to change tools to do the second half of the part.
    Thanks guys.
  12. Likes chip_maker, Ox, Mtndew, malkey liked this post
  13. #29
    Virginia
    26,222
    7561
    8257
    Seen a fella at Booger King last night that had a "Fighting Machinists" T-shirt on.
    I asked him about it.... ???
    Seems it'a all about inter termoil.
    CNC crowd got skimmers for rebicycling that.
    Tee-shirt about fightin' may indicate he's gettin' holes off-center, anyway. To-home, if not also on the job.
    Lot 'o that going "around" lately, just not on concentric askis-ease.
  14. #30
    Oct 2007
    SPAIN
    3,208
    1706
    1132
    You say it's repeatable and more "out" left to right.
    Which would assume the x axis?
    So clock your drill, or move your x shift by half the amount it's out?
  15. #31
    Jan 2014
    Coventry RI
    1,132
    1359
    897
    Quote Originally Posted by barbter View Post
    The part is round, and spinning in a lathe chuck. Exactly which side is the "left"?
    Someone tried to explain this early on in this thread, but it fell on mostly deaf ears it seems. When measuring position error between two round features, the error can always be expressed as being in only one axis, or any combination of x and y you want, just rotate the part! That's why it's typically thought of as runout and expressed as TIR, not position error, but, what ever floats your boat I guess.
  16. #32
    Jan 2006
    New York
    1,597
    681
    781
    Quote Originally Posted by Derek Smalls View Post
    I'm thinking that was an expert level troll right there.
  17. Likes barbter, Ox liked this post
  18. #33
    Virginia
    26,222
    7561
    8257
    Aye. Termoil will float a boat,
  19. #34
    Jun 2012
    Michigan
    4,603
    4210
    2768
    Pop in a center drill and go .01" - .03" deep. Just enough to put a tiny spot for the drill.
    Then drill the part and tell us the concentricity.
  20. #35
    Nov 2014
    Florida
    3,444
    1483
    1627
    Post #28 says he has fixed the problem.. Not sure what the additional comments are for (except this one LoL)
  21. Likes Mtndew, Matt_Maguire, Ox liked this post
