Lathe multiple parts from one bar.
Likes Likes:  0
Results 1 to 18 of 18
    Apr 2007
    Melbourne Australia
    256
    50
    32
    Default Lathe multiple parts from one bar.
    SL3 Fanuc 3T.
    Is there a way machine several parts from one bar without moving the bar or resetting program zero and resending it to the machine each time?
    52mm ID chuck, 60mm OD Bar of 6262 Al. Each part is 13mm long. Hoping to be able to machine and part off several pieces. at a time.
    Sep 2007
    Washington
    5,427
    225
    1698
    You can simply model the multiple parts directly. It's inelegant, but it works.
    Regards.
    Mike
    Jan 2019
    Arizona
    950
    84
    347
    There are several ways to do it, best one being mikes way (above)
    you can also us a shift xx amount of difference in sub programs, but if you screw up or hit reset your f'd and can crash.
    if its just a straight id and od all you need to do is cut off, then do the i.d and o.d. to length and run your cut off tool for each part length
    but if your new to lathe programing and running a lathe do it the old SAFE way feed to a stop hit the button make a complete part and repeat. Or program it all in like Mike says.
    Ive done it a bunch of different ways in the past however, if you have other things running at the same time( multiple machines) and cant stay on that Particular machine do it one at a time,
    I am assuming you dont have a bar feed and hoping to save time?
    Apr 2007
    Melbourne Australia
    256
    50
    32
    Delw, No bar feed. Even if i did i dont think it would push a 60mm bar through a 52mm hole....
    Bars that fit through the spindle i machine a piece, part off then move the bar the required distance and hit start again. Quick and easy with verniers.
    These parts are tapered on the OD and ID. More to save material than time. Will end up with more stub material than parts doing them individually.
    Aug 2005
    CT
    7,960
    352
    1959
    Does your control have multiple workoffsets like G55, G56 etc. ?
    How about G52?
    Short of that, I'll let the geriatric G10 proponents chime in.
    Dec 2018
    133
    329
    42
    Option 1 would be to use the same operations 6 times with G54 G55, G56, G57, G58 and G59.
    Option 2 is to program it all. Assuming your partoff tool is 3mm and leave 1mm for facing, first part is Z0.0, second part is Z-16.0, third part Z-33.0, fourth Z-50.0, fifth Z-67.0, and so on to however many parts you can get out of the bar.
    The stop method works too but I think it's more dangerous if the operator is not very experienced.
    Apr 2007
    Melbourne Australia
    256
    50
    32
    Fanuc 3T, so im stuck with G50 only, that i know of.
    Feb 2017
    98
    8
    32
    Is it the programming you're looking for help with or workholding?
    Apr 2007
    Melbourne Australia
    256
    50
    32
    Programming.
    Workholding i have no options. Piece of 60mm OD bar sticking out say 150mm should get 8 parts.
    Dec 2012
    Se Ma USA
    1,741
    138
    950
    I run 2" bars through the spindle. Doing it for years and the full length of the spindle. I use spindle liners to keep centered and balanced. Most of my parts are finished by the sub spindle, but when it is chuck work I use the sub as a bar puller. That machine can fit a 60" bar completely in the spindle.
  11. #11
    Sep 2007
    Washington
    5,427
    225
    1698
    Quote Originally Posted by Kenre View Post
    Another option then, if you were planning on a 2nd op to clean up the backside, is to saw pucks that are part thickness + 1/8" + a little more for facing, and hold them with Versa Grips. They're like Talon Grips but for round stock. With my 4mm parting blade it ends up being about the same lost material. You have the added benefit of not having the first couple parts done "way out there" and maybe chattering.
    Regards.
    Mike
  12. #12
    Sep 2007
    Washington
    5,427
    225
    1698
    Delw, No bar feed. [snip] Bars that fit through the spindle i machine a piece, part off then move the bar the required distance and hit start again.
    I have an air plunger in my SL-2's spindle bore that pushes to a work stop in Tool 8. Lets me bar feed 3' bars. I can send you details if you're interested.
    Regards.
    Mike
  13. #13
    Sep 2005
    Oakland, CA
    2,670
    382
    755
    Are you already using G50 for your tool geometry offsets? If so just edit your G50 return move to shift position the amount you shortened your bar from the last part and rerun the program. Then on the last return move, add the shift back in and return to your original start point and advance your bar.
    Or, use G10 to update you work shift for the next part if you don't want to mess with the G50. Since 3Ts are pretty basic I think those are your options. G10 is not the perfect solution but it will work.
  14. #14
    Jan 2012
    indiana, usa
    191
    48
    Cheap and dirty way would be to run 1 part off each chunk, then reset zero and run 2nd part off all chunks. Repeat as needed. Easy way would be to call you
    r program as a sub program. I don't remember how your control wants the sub called, but something like this:
    M98P1
    G50W.5
    M98P1
    G50W.5
    M98P1
    G50W-1.0 (shift zero back to starting position)
    M30
  15. #15
    May 2019
    Michigan
    1,450
    409
    654
    Quote Originally Posted by chad883 View Post
    M98P1
    G50W.5
    M98P1
    G50W.5
    M98P1
    M30
    Works, but can be a bit risky. i.e. stop the program in the middle for whatever reason and watch it kiss the jaws at cycle start.......
    I would personally use absolute with G10, but I am not fluent in Fanucese.
  16. #16
    Apr 2007
    Melbourne Australia
    256
    50
    32
    Thanks! gives me a couple of options. I will workout the easiest most foolproof way to suit.
  17. #17
    Apr 2007
    Melbourne Australia
    256
    50
    32
    I can get 4 parts max before running out of memory.
    This was having the code with the new Z position each time. Longhand, i better study up on G71 G70 etc to save memory
  18. #18
    Nov 2013
    Utah
    4,884
    1291
    2760
    Quote Originally Posted by ChipSplitter View Post
    How on Earth would that happen?
    If you are incrementally shifting Z zero closer to the Chuck after each part, then reset, it's just going to go back to where the first part was.
    R
