Lathe offsets
Results 1 to 10 of 10
Thread: Lathe offsets
    May 2018
    UNITED KINGDOM
    Default Lathe offsets
    Hi
    Can anybody go through cnc lathe offsets with me ,I get confused some times with i/d ,o/d wear offsets and when to use negative or positive .and when you use screw cutting tool in a bore what way to move offset to make thread looser,
    Many thanks
    Feb 2006
    Republic of Texas
    2,949
    Plus makes OD/ID larger. Minus makes OD/ID smaller. Applies to Fanuc, Fagor, Anilam, GE1050. Don't know about others.
  3. Likes SND, Houndogforever liked this post
    Guest Guest
    What happens on a Z offset will vary depending on type of lathe. I have a fixed headstock where if you moved a cut-off tool Z minus the part gets longer, on a sliding headstock Swiss Z minus on a cut-off makes the part shorter. Both are Fanuc, pretty sure all brands are the same.
    Sep 2015
    Ohio
    1,833
    1202
    1975
    Adjusting a wear offset - will move into the work. ie: OD smaller, ID bigger.
    A wear offset adjustment + will do the opposite.
    Oct 2015
    Oregon
    539
    244
    434
    After disintegrating a 1/4" tap on my newly acquired lathe,I agree those + & - signs can be confusing.
    (wow, that sounds like I"m a dick.)what I am trying to say is I'm still calling my son over to help me figure out tool setup on that damn thing.
  7. Likes Bobw liked this post
  8. #6
    Sep 2005
    Oakland, CA
    3,042
    612
    986
    Ha Ha- all the above is true except on a machine with a minus side X axis.
  9. Likes Kenre liked this post
  10. #7
    Sep 2010
    Victoria Australia
    4,165
    1777
    Quote Originally Posted by Booze Daily View Post
    Hello Booze,
    With a typical Turning Centre, were both boring and OD tools are performing on the plus side of the machine's centre line, adjusting the wear offset in a minus direction will result in both the OD and ID being machined smaller. The inverse occurs when the offset is adjusted in the plus direction.
    If the tools operate on the minus side of centre line, then a minus offset adjustment will increase the size of the OD and ID; vice versa if the offset is adjusted in the plus direction.
    Regards,
    Bill
  11. #8
    Jun 2011
    New Jersey
    1,680
    911
    740
    On most controllers there is a calculator function so if you want an ID larger you would "add" to the offset. If you want an OD smaller you would "subtract." Most controls have a "measure" function so the machine can calculate proper lathe/distance.
  12. #9
    Sep 2015
    Ohio
    1,833
    1202
    1975
    Oops. I was thinking of wear on a mill using G41/G42.
    That doesn’t affect diameter size on a lathe.
  13. #10
    Jun 2007
    Easton, PA
    486
    15
    Quote Originally Posted by Dan from Oakland View Post
    Yup. Set up Fagor control gangsters normally cutting on negative side so can run all tools M3.
