Lathe Rigid Tapping
Results 1 to 17 of 17
    Aug 2018
    Iowa
    14
    Default Lathe Rigid Tapping
    Can anyone recommend a good holder for rigid tapping in a lathe? I am going to do alot more tapping and need to good tool life.
    Jun 2013
    Oregon
    1,553
    549
    930
    What kind of lathe?
    Feb 2014
    Sunny South West Florida, USA
    2,881
    10698
    3274
    Yes. But if you're not gonna give us any information, we can't help.
  4. Likes Mtndew liked this post
    Aug 2018
    Iowa
    14
    Sorry Doosan Lynx 2100LSY
    Jan 2019
    Missouri
    123
    32
    19
    On-center tapping with the lathe spindles? Or driven tool tapping?
    Aug 2008
    Paso Robles, CA
    139
    26
    18
    ER32 collets are an acceptable way to hold a tap.
    Aug 2018
    Iowa
    14
    On center tapping
  9. #8
    Oct 2019
    North Carolina
    11
    8
    I tap 2" 11 1/2 pipe thread in my lathe. Stick the end of the tap in the bored tapered hole. Live center in the end. Crescent wrench on the flats on the tap with the wrench end on the cross slide on a leather welding glove. Lathe in low gear. Lube the heck out of it and go. Bump on and off. Put slight pressure on the tail stock while starting, after a few threads it will feed itself. Continue lubing and bumping on and off. Has worked for me. Good luck.
  10. #9
    Sep 2010
    Victoria Australia
    3,723
    1468
    Quote Originally Posted by Ifitsmetal View Post
    Hardly a method that will lend itself well to a CNC application.
  11. #10
    Jan 2011
    SF Bay
    372
    50
    215
    Greetings,
    GenSwiss stocks some pretty nice floating tap collets that fit various sizes of ER.
    ( Floating Tapping Collets for CNC Machines - GenSwiss )
    I've used the ER-20 sizes for years with great success.
    I've been told (but don't do it myself) that the best way to use them is to underpitch the thread pitch very slightly (0.03120 instead of 0.03125 for 32 pitch for example) That causes them to expand on the way in, and retract on the way out, to let the tap float its own pitch.
    I didn't know that to start, and got great results with just doing the pitch accurately, so I can't see any reason to change. But I pass along the knowledge anyway.
    FWIW
    Brian
  12. #11
    Feb 2014
    2,881
    10698
    3274
    Quote Originally Posted by Alberic View Post
    Greetings,
    FWIW
    Brian
    Pretty sure using a floating holder is contraindicated for rigid tapping. At least, on a machine that's in good shape.
  13. #12
    Jan 2019
    Missouri
    123
    32
    19
    Unless that is a very new machine,and something has changed. Most lathes do not "rigid" tap with the lathe spindles. If you want to rigid tap on-center you will have to use an axial driven tool.
    If you must use the lathe spindle you will have to use a tension compression type holder. Just like the good ole days.
  14. #13
    Feb 2003
    Alabama
    520
    24
    281
    I’ve run quite a few jobs tapping on center with the main spindle. No tension/compression holder required. 5yo Doosan Lynx.
  15. #14
    Feb 2004
    Staten Island NewYork USA
    3,762
    1106
    1797
    Quote Originally Posted by GENERALDISARRAY View Post
    Ummm we've been Rigid Tapping in our CNC lathes since 2000.
    As to holders I use ER-32 Collets.
    I originally purchased some funky Tap holders with square drives that do not slip...kinda need them for bigger taps, say over the 1/2-13 in tougher materials. However under that the ER's are more then fine and its nice if they give some letting you know something is off instead of a crunching noise.
    IF I want more tool life and if alignment is not 100% I will use a Tension/Compression holder like the ones Mari-Tool sells...also ER-32 Collet. Down side is a dull tap may take a hair longer to engage and that screws with your depth some.
  16. #15
    Jan 2014
    Washington
    4,655
    845
    2531
    With many controls, rigid tapping with the main spindle of a lathe has been around for over 25 years. Whether or not the ability is spec'd and implemented though is at the machine builders choice.
  17. #16
    Jan 2007
    New Jersey
    953
    464
    470
    Hello, I work for Doosan. Like almost all other machine makes, you should not need any special collets or holders for rigid tapping. Unless maybe for very large taps. We do all of our rigid tapping with standard ER collets mostly.
    If you need any other help with your machine, contact us here at the New Jersey office. 973-618-2500
    Paul
  18. Likes Ox, DouglasJRizzo liked this post
  19. #17
    Jun 2011
    New Jersey
    877
    527
    336
    For rigid tapping on the Doosan, a standard collet chuck and collet should suffice. Tension/Compression holders really only factor into float tapping.
    Remember that the syntax for tapping is important:
    M5 P11 (main spindle) or P13 for sub, P12 for live tool
    G0 G54 G99 T0303
    X0 Z.25
    G97 S250 M29
    G84 Z-1. F.05
    G80 Z2.
    G28 U0
    etc
    To calculate thread lead "F" value = In IPR mode (G99) - 1/# of threads. In IPM (G98) mode it's Rpm/#of threads.
