lathe / swiss screw tool radius? Stainless 316
Results 1 to 14 of 14
    Apr 2021
    Default lathe / swiss screw tool radius? Stainless 316
    Hi all!
    I am designing a small shaft that needs a little flange. there's a lot happening in a small place, so i want to model the tool radius instead of a sharp corner.
    shaft is ~.1" diam, stainless 316.
    this will be a production part (100/year). I suspect made on a screw machine.
    What is a reasonable (minimal) corner radius? I am hoping you will say .003"...
    cheers!
    ssr
    Jun 2014
    New Jersey
    377
    398
    203
    Quote Originally Posted by subsearobot View Post
    Hi all!
    shaft is ~.1 diam, stainless 316.
    cheers!
    ssr
    so, you say swiss screw, so is that diameter .1 mm or inch?
    I assume inch since your radius is in inch, but it's not clear..
    next you don't define what is going on, the amount of stress... you add a radius to kill off the stress riser, and also to handle any other torque that needs to be relieved.
    I won't have the answer since my engineering background is from the 70s and I didn't finish it and never put it to use.
  3. Likes subsearobot liked this post
    Apr 2021
    shaft is ~.1 inch diam.
    also worth noting- I am not looking for design advice, but for DFM advice.
    Jul 2006
    Hillsboro, New Hampshire
    13,623
    2995
    9122
    Speaking as a Dumb F'ing Machinist: sure, do whatever you want.
    Speaking as a mechanical designer (but not an engineer): RPM, shaft and flange lengths, mechanical supports and stress on those, attachment methods, torsional stress, balance and resonant frequency issues, blah blah would be good to know.
    But yeah. A .003" radius is good. Perfect, in fact. Better than whatever Brunel would have come up with, that's for sure...
    Guest Guest
    For the record your typical insert tool corner radius is .008 and up on front turn, back turn and groove inserts. Try to design the part around that. Of course smaller radiused tools are available but in a smaller selection.
  7. Likes Nerdlinger, SND, Fancuku, Tom Lg liked this post
  8. #6
    Apr 2021
    Quote Originally Posted by Dualkit View Post
    awesome. typical insert tool corner radius is really the question that i was trying to ask. I'll start there, and soon learn that i need a custom tool...
  9. #7
    Guest Guest
    For the record, typically the smaller the radius, the less tool life, and 316 is typically hard on tools, and the smaller the diameter the more of a PITA it is to work with materials that aren't friendly. At that .1 diameter I believe as you mentioned it is a Swiss screw machine job.
  10. #8
    Aug 2013
    Chicago, IL
    1,271
    915
    512
    .004” isn’t too hard to find either, but again huge trade off with insert life. Is cutting a shallow and narrow groove below the shoulder an option?
  11. #9
    Guest Guest
    Quote Originally Posted by Nerdlinger View Post
    I have used front turning inserts with a .001 corner radius for a medical device company that wants sharp fillets, even on 303 they don't seem to last very long, even crawling on SFM.
  12. Likes Nerdlinger, Rick Finsta liked this post
  13. #10
    Sep 2017
    Wisconsin
    1,383
    360
    855
    They think physics don't be like it is, but it do.
  14. Likes TeachMePlease, lumley32 liked this post
  15. #11
    Feb 2014
    FL
    4,402
    13730
    5284
    I can get inserts down to .001" radius. I don't like using them. .003" and .004" are fairly common, but they're going to add to manufacturing cost because they'll still have poor tool life. .008" is the absolute minimum I like to program with, and even better if it can be .010" or .015" so I can program a radius move to generate the radius, instead of just ramming the insert into a corner...
  16. #12
    Jan 2007
    Flushing/Flint, Michigan
    10,578
    619
    8546
    Anything below a .006 true radius on carbide is a problem and cost to make should go way up.
    Rads down in the thou or three are often put on by hand and if checked under 350x mag don't really look like a radius and the clearance will not be right so tool life is all over the place.
    Seen so much lying in this, but the customer has 30X so won't know or worse yet the maker is at 32x. User just thinks it wore out fast. Like Doritos, eat em up, we will make more.
    An upsharp carbide tool corner lathe or mill will be cutting a .001/.002 corner very quickly in use in metals.
    How do you intend to check this finished part radius?
    Can this corner be undercut slightly to prevent interference with mating part and allow a bigger rad or tool corner breakdown?
    This is how toolholder pockets are often made so as not touch the sharp and unused side of a double sided insert that is sitting down if no shim seat.
    For sure it can be done and the micro-maching guys live in this world all day long but try hard not to design around such radius.
    It seems so easy in the CAD where the world is perfect. If only it worked so nicely when making parts to be shipped.
    Bob
  17. #13
    Dec 2012
    Se Ma USA
    2,240
    180
    1219
    Hi all!
    cheers!
    ssr
    100 per year is a production part?
  18. #14
    Feb 2013
    Idaho
    850
    192
    974
    .008” almost never get complaints, less in 316 is going to be no end of issues with finish, speed or edge breakdown.
