Lathe thread tool setting - Page 5
Page 5 of 6 FirstFirst ... 3456 LastLast
Results 81 to 100 of 105
  1. #81
    Nov 2013
    Utah
    4,640
    1222
    2603
    Quote Originally Posted by deadlykitten View Post
    and i am done with this thread
    Well now that worked.
    Now that the OP is completely gone, wouldn't be surprised if the OP didn't visit Practical Machinist again, ever. A lot of energy spent running off a stray.
    Maybe we need to swallow a proverbial dog? 100 points for the reference.
  2. #82
    Jan 2014
    Washington
    4,680
    847
    2543
    ......is it normal for that radius to be bigger than the clearance between thread and shoulder ?
    Another stupid argument. Very rarely could this ever possibly be an issue. The actual cutting edge of a threading insert is at the very least a half pitch from the from edge of the insert. Add the .1mm clearance to that and you'll have plenty of room for the tool nose radius on the turning tool.
    Better yet, be done trashing this forum!
  3. #83
    Aug 2016
    ALAND ISLANDS
    1,393
    43
    96
    in attached image, left:
    ... yellow : repetability for | Z_offset_thread_tool - Z_offset_turning_tool | measured at tool senzor
    ... blue : repetability for | Z_offset_thread_tool - Z_offset_turning_tool | measured with increased accuracy, thus not the senzor inside the lathe
    ... azure : ipw
    ... green : tool corections after machining 1st part
    ... red : tolerance for insert crafting and clamping repetability
    ... pink : remanent tolerance for setup stability : less<42%
    real clearance will be 0.042, and i have been gentle with numbers, thus values on a sharp lathe
    enhancing stability ( attached image, right ) :
    ... turning at Z-40
    ... threading at Z-39.9+[ azure + green + red ]
    ... replacing measuring tools at senzor with more accurate instruments
    ... using a single corection for both tools, example :
    ...... Z offset turning tool :33.219
    ...... Z offset thearing tool :72.494
    ...... editing one of those will change both, thus inputing +0.1 into 33.219, will automatically shift 72.494 to 72.594 and viceversa
    ... pink : remanent tolerance for setup stability : 98%
    real clearance will be 0.098
    at this point, a good start is achieved, but setup stability will have its word
    after a trial period, machining 100 parts, etc, code for thread tool should be changed :
    ... threading at Z-39.9+[ azure + green + red ] + [ setup_stability ]
    setup_stability value can be obtained from statistics on charts of tool corections
    considering the medium value = med, setup_stability will be med*coeficient_factor, where coeficient_factor = 1.2, 1.5, 2, etc
    at this point, setup stability is achieved
    i have not included "palier desyncronization" aspects, which is more important for threading operations, and less important for cilindrical turning operations
    some cnc producers make public such values, as being machine dependant constants
  4. #84
    Sep 2010
    Victoria Australia
    3,725
    1469
    ... yellow : | Z_offset_thread_tool - Z_offset_turning_tool | measured at tool senzor
    ... blue : | Z_offset_thread_tool - Z_offset_turning_tool | measured with increased accuracy, thus not the senzor inside the lathe
    ... azure : ipw
    ... turning at Z-40
    but here you are back again to woffle on.
    Do you really think any Forum Member in the know takes you other than with a pinch of salt? Anyone that would suggest machining a shoulder feature AND thread to the shoulder with the same tool, has shown themselves as knowing extraordinarily little about machining and having infinitesimal experience. That one is amongst your greatest fails; it was really good for a laugh.
    As I've suggested in earlier Posts, endeavor to enroll in a machining class for beginners and maybe you will learn some of the fundamentals. However, there is no guarantee with you, that you will learn.
  5. #85
    May 2008
    SOUTH AFRICA
    1,627
    1191
    667
    ... azure : ipw
    ... turning at Z-40
    So is all this bullshit that you type on here directly related to the way that you figured out how to thread a donut?
  6. Likes litlerob1 liked this post
  7. #86
    Sep 2010
    Victoria Australia
    3,725
    1469
    Quote Originally Posted by NAST555 View Post
    Hello NAST555,
    I noticed that the Idiot is waxing lyrical about "palier desyncronization" on the Zone. At least he's not polluting just PM with his lack of knowledge, but trying to Fuck Up multiple Forums. He's getting a similar reception there,so it would seem the people at the Zone do have taste.
  8. #87
    Mar 2014
    CANADA
    Ontario
    801
    801
    161
    deadlykitten do you machine stuff the way your posts read? Glad i am not getting those items.
  9. #88
    Sep 2010
    Victoria Australia
    3,725
    1469
    Quote Originally Posted by twr View Post
    What can one say; he doesn't know any better. That's what lack of skill does for you.
    Regards,
    Bill
  10. #89
    Jun 2004
    Melbourne Australia
    5,458
    Quote Originally Posted by angelw View Post
    Hello NAST555,
    On that forum he is from The "North Pole".
    We all know your posting from Romania. North Pole / Aland. You must be really embarrassed to be from Romania?
    What'S up with that?
  11. #90
    Jun 2004
    Melbourne Australia
    5,458
    Somehow he seems to understand the DMF-Tom Syndrome.
    That's made it into public knowledge. Urban Dictionary: DMF Syndrome
  12. #91
    Aug 2016
    ALAND ISLANDS
    1,393
    43
    96
    Quote Originally Posted by machtool View Post
    dmfTomB is like a gentle giant, he never said nothing bad to nobody ... and here you refference him again
  13. #92
    Jun 2004
    Melbourne Australia
    5,458
    Give me a minute. I'll work out the syndrome you both suffer from. I know the definition, its basically where you think you know, more than you know.
  14. #93
    Sep 2015
    Ohio
    1,154
    708
    1144
  15. Likes NAST555, machtool, chucker, litlerob1 liked this post
  16. #94
    Sep 2010
    Victoria Australia
    3,725
    1469
    Hello Phil,
    You know, he may be more patriotic than you give him credit for. If he were to excluded himself from Romanian statistics, the IQ of the country would improve.
    Quote Originally Posted by Booze Daily View Post
    The prize is yours BD; you nailed it!
    Regards,
    Bill
  17. Likes Vancbiker, chucker liked this post
  18. #95
    Jun 2004
    Melbourne Australia
    5,458
    I have a son 24 year old, that will be a PHD doctor of Neuroscience, just beyond this time next year. Fully funded scholarship. In his research of the brain. I've proffered, if he happen's to find any thing worth a paper. He should call it the Larue - Kitten effect. I'm not kidding about that. Fellows and scholars | The Brain Dialogue
  19. #96
    Jun 2004
    Melbourne Australia
    5,458
    You have a point. I should try harder not, to pick on the intellectually challenged like You & Tom. Despite your being more often WRONG and dangerous advise's.
    We should just let that slide? I regret to inform you, many of the members here have hard graft, earned here by years of contribution. Your random thought farts, will never, never outweigh those.
    That's the wealth of our forum. Free resources. I wish you would STOP trying to devalue the place. Think about it like a stock market. It was worth $1.00 per share, until you joined. Now its about $0.66 And our shares are plummeting.
    Please Fuck off.
    Best regards Phil.
  20. #97
    Sep 2010
    Victoria Australia
    3,725
    1469
    ... azure : ipw
    ... turning at Z-40
    Forget the "palier desyncronization" aspects, your chart doesn't incorporate the "Brain Dead Factor" of trying to use the one tool (one Insert) to machine the shoulder feature and Thread close to shoulder feature.
    You have brought joy to some lives, you may be pleased to know. I emailed copies of your Post suggesting the single insert for turning and threading to a shoulder to all my clients. Laugh, I can't shut the bastards up.
  21. #98
    Jun 2004
    Melbourne Australia
    5,458
    Steady on Bill.
    You must have missed.
    I'm all for a good start, or was that a good set up, or a good stability, or a good word. Stuff it I'm lost. I'm not sure who cum's first.
    palier desyncronization almost make's more sence.
    Phil.
    P.S Try the shrimp in the Buffet.
    Bill & Phil in Vegas. We will be here all night..Boom boom.
  22. #99
    Jul 2013
    Indiana
    3,235
    4727
    1630
    Phil,
    That's really something to be proud of! Good for him!
    Brent
  23. Likes machtool liked this post
  24. #100
    Jun 2004
    Melbourne Australia
    5,458
    He has 1,590 posts over there.
    Head office is asleep at the wheel. They cant have forgotten the Abene issue of 1998.
    He has a place to go, just ban him from this one. Please.
