I'm trying to align an old okuma Lb10.
after my initial alignment it started drilling nasty holes so I checked and there was an obvious misalignment.
I realigned the drill as it was pointing down slightly. tested a hole and re-ran the program to find that the drill was off centre again.
I redid the alignment and triple checked through the process that it was still aligned after tightening the coupling. After cycling the tool change and sure enough the drill had drooped out of alignment after the tool change.
Can anyone offer advice on what might be happening?
