I am trying to diagnose an intermittent issue with a Leadwell LTC-20BP with Fanuc 0-T where when cutting a bushing, an OD and ID error appears - ID and OD become too large.
The operator adjusts offsets to get the correct dimensions, then after a period of time in the same shift the issue will reverse and the the ID and OD will be too small.
The amount of error is consistent during the period it has changed, but each time the error appears, the magnitude of error is not consistent. Error will range from 0.006"dia to 0.016"dia.
I have not been present when the error is evident to run through indicator tests, but the machine has been taken out of service to fix the problem.
I have looked at the turret mounting, it looks solid, no crashes reported recently(problem comes and goes anyway). The indexing is very clunky and sometimes will not complete the rotation(not clamped).
The turret is not well balanced, but the tools are not heavy. Clunkiness is still evident with the turret face removed.
I have started disassembly of the turret to get to the curvic, but I'm hoping to get some advice on things to look for.
The turret has a solenoid activated stop pin that appears to stick sometimes. Should I pull apart the stop mechanism and shock dampener?
I was told the operator did some indicator checks already, I will do my own in the morning.
Your help is appreciated.
