Least material to hold w/Talongrips?
Results 1 to 8 of 8
    May 2002
    South Central PA
    14,613
    2842
    4350
    Default Least material to hold w/Talongrips?
    I thought this was discussed previously here but I can't find it. I'm making some parts that finish at .250" thick from 1018 CRS bar. I bought 5/16 thick material, thinking I could hold one side in talon grips, skim .010 off the top, profile mill another .250 down the side leaving .045 - .050 on the bottom to remove in a 2nd op. I just double checked my talongrip jaws and the grips stick up about .080 which won't clear. Has anyone here found gripping on less material to work? How little have you held by successfully? These are small parts, will be profiled with a 3/8 EM, not trying to set a record for speed, probably 100 parts or so. 2 parts at a time, approx 2" diameter, from 5/16 X 2.5" material,
    Nov 2015
    Colorado
    390
    63
    196
    right now im hogging a big piece of 7075 aluminum holding onto .059 stock. Heavy cutting and its doing just fine. You need to make sure there is no fillet or chamfer on the edge of the stock where it is clamping. I would not want to hold on to anything less than 0.05 stock no matter what type of machining youre doing with the Talon Grips, but you could prob get a away with 0.04
  3. Likes Mud, mhajicek liked this post
    Jan 2013
    Gilbert, AZ
    7,275
    9704
    9335
    Agreed that the amount is dictated by the rad on the bottom of the stock. If it is nice and square, .050" would probably be fine.
  5. Likes Mud, Winterfalke liked this post
  6. #4
    Aug 2013
    Chicago, IL
    1,271
    915
    512
    If the part specs would allow for it, you could go over the profile after flipping and then chamfer deep enough around the profile to reach the mismatch line. So a .01” chamfer would give you an extra .01” to hold on to with the talons...
  7. #5
    Jan 2006
    143
    185
    10
    Just put some shims under the material and test it, I think it will be fine. As with others, my only problems have been when the rad on the material is too big.
  8. Likes Mud liked this post
  9. #6
    Sep 2017
    Wisconsin
    1,383
    360
    855
    0.050" is the lowest I've gone and that is with shim stock under the material to hold it up in place. I had to square that part because there was too big of a radius on the raw extrusion to grip.
  10. Likes Mud liked this post
  11. #7
    Mar 2011
    Huron
    1,459
    2537
    918
    I regularly held aluminum to be faced with talon grips and pitbulls with only .040", and I made sure that stock had no radius where I was clamping it. Only had issues if someone tightened up the pitbulls too much. Or didn't tighten them at all. Or didn't clean the chips out, or put parts in with huge raised gouges in them. I worked with idiots, come to think of it....
  12. Likes Mud, Garwood liked this post
  13. #8
    Sep 2017
    Wisconsin
    1,383
    360
    855
    I've found with the Talons I get better results if I clamp hard, then release, then reclamp.
  14. Likes Mud, EnginCycles, Winterfalke liked this post
