so. i havent ever thought about this until recently after checking voltage again and being a touch more knowledgeable than i was years ago when i installed a RPC for my fanuc mill. i just put in a lathe and the transformer gives the wiring option of 210,220,230,240,and then 460-480. so i wanted to make sure to be mostly correct there, and checked it again. averaging about 240-245 most days here. now, from what ive seen ,thats a bit high for what you want to see. so ,my question is, on my mill, (which is a 94 excel 510,fanuc)should i be looking into a transformer to reduce the voltage a bit? FYI, its been running this way just fine for probably 6 years now.
