For that size rail I would guess the standard stack height tolerance of a rail and block assembly is +/-.002" or .004", I can't remember if the .004" was total or +/-. Way more to it than this but these are the biggest deal killers to what you want to do.
I replaced the rails and blocks on one of my mills a few years ago so had to learn all this, and found out there are WAY more details to deal with than I ever imagined!
These are C1 preload according to bearing manufacturer website. That’s the lightest preload they offer, but higher preloads affect bearing life negatively with the increased tolerances.
What is stack height? This machine was once a $20-30k (maybe more) CNC Router. It doesn’t need to, or will it ever hold the tolerances of a mill, but it was designed to be a production/prototyping machine, and once I get the rest of the slop out of the drives, it should do its job satisfactorily for a while longer.
I learned today that when there is an odd sized bolt, you probably ought to leave it alone... the end caps of the bearings where the grease fitting is located are secured with two small bolts with 4.5mm heads. Had to order a special but driver, and then turn the o.d. of the nut driver down about .035” in order for it to fit into the recesses for the bolts. I popped the end cap off, because I wanted to see if the grease was making it to where it belonged.... oops. Amazingly I was able not to spill any of the balls onto the floor and lose them, and I was able to carefully wiggle it all back together. But I’m not going to make the mistake of dismantling one again.
The manufacturer of the router sells a very similar looking star bearing truck, so I imagine that they are field replaceable without consequence. When your machine isn’t designed to hold tenths, it is a little more forgiving to repair. Star/rexroth still makes this particular bearing truck, so, I guess unless I want to replace all of the rail, I will stick with them. Even if I had to replace all the rails and all of the reduction drives, rack, and pinion, I’m still the price of a new car cheaper than installing a new machine.
