A little Help with an old Anilam Crusader M control
Likes Likes:  0
Results 1 to 6 of 6
    Jun 2019
    Connecticut
    Default A little Help with an old Anilam Crusader M control
    Hello,
    I recently purchased an old Acra mill with an Anilam Crusader M control (3 Axis). Everything seems in good shape and the control seems to work fine. So far we have machined a few relatively complex plates. I have the control sending and receiving programs from a laptop - all of which are programmed at the control thus far.
    My problem is with holding zero on the Z axis. We set X, Y, Z zero then start setting the tool offsets. Somewhere in moving around we go to start the program and Z zero will change. Sometimes way off, sometimes .300 off. I figured that somewhere along the line we were switching tool offsets and maybe then resetting zero on the wrong tool offset. But we just ran one part, 4 tools all worked fine. moved around a little to put the next part on (same program) and next thing you know Z is all the way up and reading -2.2289 its driving us mad... its like if we turn our back on the machine z changes. never had an issue with the X or Y changing.
    Any advice on this old machine and finicky control would be appreciated.
    Thank you
    clint
    Feb 2013
    Idaho
    587
    123
    653
    I had one of those years ago. Mine would do the same thing. It was as if the entire Z axis would shift when the servos kicked on. Not all the time, but I would occasionally hear it kind of make a thunk noise and Z would shift. It's been many years ago, but I think it had something to do with how the Z servo would disengage to allow manual drilling with the quill.
    Feb 2011
    Indiana
    23
    15
    13
    Your Z axis encoder could be misaligned, contaminated or worn out. Skipped encoder counts would cause random position jumps like that. Is there a way to disengage servo and move quill by hand while monitoring its position? If you can replicate the error manually, then encoder is very likely to blame. I would check the mounting and alignment first, then try to clean it following proper procedure.
    Dec 2013
    Fort Wayne, IN
    616
    686
    225
    Talk to Jerry, he can get you setup. 716-490-1462.
    Jon
    Jun 2019
    Connecticut
    Thank you, I believe I talked to Jerry looking for a tape for this machine. I'll double check the Z encoder, and pay closer attention.
    thanks for the advise. I'll post back if I learn anything.
    cheers
    Apr 2004
    Milwaukee,WI
    1,222
    7123
    961
    If there are no mechanical issues with the z axis, check the encoder coupling.
