Does anyone know the best cycle format for skiving on a okuma multus u4000?
So are you looking to solve Skivving as what I think it is? Or am I totally on crack?
Rob,
I can't speak to your pastime proclivities, but it's not what we in the Gear World have typically considered Skiving. Skiving has traditionally described a type of super finishing operation performed upon mostly finished Involutes*, and more oft than not in a hardened condition. For the last decade, MTBs have been trying to coin a buzzword to describe their latest attempts at Gear Making in multifunction machines by using Skiving to mean something COMPLETELY different. Add to this my own admitted personal disdain for their err... shall we say... "misleading" at best claims of capability and accuracies and you arrive at the equivalent of "Billet" and "Military Grade" bullshit. ( at best ) These days, the MTBs are using it to describe a process that is a combination of something resembling a Shaper Cutter rotating at high speed, in coordination with the work also spinning, and using axial movement to traverse the Face Width. It DOES work, and has obvious applications, but the expenditure and actual resultant guaranteed quality are not what you find in literature or from the salesmen's mouths and offer little to no gains for most shops and processes that I have seen, yet. Now where'd I leave my coffee...?
Rob,
Sandvik has a special inserted skiving cutter and show the process. I'm just trying to figure out if there is a easy lap code. My company uses Catia. I'm sure we can figure it out but if someone has an easy lap or macro then it would help. The machines do have a gear cutting package but the books suck.
External involute spline..So you are thinking about using the Form type tool where the Inserts are the approximate shape of the Space of the Gear tooth.
What type of gears are you thinking of making? A Spur gear should be fairly straight forward with G85-G81 and a Curvic coupling even a Bevel gear should be okay with G85-G82.
R
Notice
