My Fadal is up and running and I'm making parts but now I have what I call a radius plate to machine, problem is it's a 26" radius so I need my zero point to be outside my table, does anyone know how to set my "Y" say 6" outside my table. I use to run a Cincinnati Milacron and I use to be able to set X or Y to what ever I wanted.
Lot of jabbering, including myself.. What is the actual problem???
Pick up your reference point and then offset.
OR... If you are new to Fadals, then you are new to Fadals, then it is possible
that you are doing something wrong..
How are you setting your offsets?? Are you typing SETX and SETY???
That moves the machine home position... You type SETX and SETY.. ONCE...
EVER!!!! The entire time you own the machine.
If that is what you are doing, then you aren't even using fixture offsets.
Use the fixture offsets.. First space bar menu, #4 set fixture.. FOLLOW THE DIRECTIONS.
You can then offset by going to the offset table. You can get there several ways, the
easiest is first space bar menu, #6 offsets. Then hit the space bar to get to get from
the tool offset screen to the Fixture offset screen, then literally follow the instructions
on the screen to offset your offset to anywhere your heart desires.
