Lock feedrate
Results 1 to 5 of 5
Thread: Lock feedrate
    Nov 2015
    BELGIUM
    75
    7
    Default Lock feedrate
    Hey
    i manage to make a macro for a toolsetter to measure the toollengths and check broken tools.
    But as i alredy do the fine touch in F100mm/min it stil have a big difference in measured length is the feedrate is set to 70 of 50%.
    is there any way i can block for only this line the feedrate to 100mm/min. so my measure result isnt effected by the position of the feedrate knob?
    Feb 2008
    MI, USA
    828
    63
    321
    What is the machine/control?
    On a Fanuc, #3004=2 disables feedrate override, and #3003=0 enables it.
    #3004=2
    (measure stuff here)
    #3003=0
    M99
  3. Likes jancollc liked this post
    Dec 2003
    poulsbo, wa, usa
    972
    71
    426
    yes there is I don`t have the manuals here but its a G code is used when threading that stops overriding the feed rate,, I know its not only used on lathe controls but also on mill controls for tapping …
    Sep 2010
    Victoria Australia
    3,852
    1537
    Quote Originally Posted by dandrummerman21 View Post
    #3004=2
    #3003=0
    M99
    Hello dandrummerman21,
    Close, but no Cigar. #3003 is for Enabling/Disabling Single Block
    #3004 is for Feed Hold, Feed Override and Exact Stop, Enable/Disable. There are 8 setting from 0 to 7 to initiate various combinations of the three functions.
    To simply Disable Feed Override, #3004 is set to "2". To Enable Feed Override again, #3004 is set to "0". Accordingly, the program would look something like the following:
    #3004=2
    #3004=0
    Regards,
    Bill
    Feb 2008
    MI, USA
    828
    63
    321
    Quote Originally Posted by angelw View Post
    #3004=2
    #3004=0
    Regards,
    Bill
    I have a cheat sheet for stuff like this, apparently it was wrong (i didn't write it). I will correct my post.
    Edit: cant edit posts a day later apparently.
