Looking at Advanced/Mighty VMC 520 - Page 4
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 61 to 80 of 89
  1. #61
    Jan 2014
    Washington
    4,586
    838
    2488
    Quote Originally Posted by rpseguin View Post
    .....The Mitsubishi Electric Automation guy said that my control should support 4 axis simultaneous interpolation.......
    The 300 series control could do at least 5 axis if configured with the correct boards and firmware. Your firmware may (and probably does) have 4th support. It will not be active though. There are "secret" parameters that need to be set to enable 4th support unless your display already shows 4 axes active.
  2. Likes rpseguin liked this post
  3. #62
    Dec 2007
    454
    889
    64
    I haven't read all of the threads, but.....
    I had a Mighty Viper VMC750 that was a great machine until it started to have some bugs. It got to the point that I gave up on it. It would run for a day or two and it would take 2 - 3 weeks to figure out what was wrong, actually the bug would go away and then reappear in a few days.
    Mitsubishi is a fantastic company. You can call them for tech support and they will do everything in their power to help.
    Mighty is not a great company for parts or service on their older machines. There are a "few" individuals who speak English. They will try to help you, but hopefully this will not be your primary machine.
    Parts is another story. You can give them a part number, they will ask you to send a picture of the part you are looking for. The older parts got moved out into a storage area. It will take a day or two if you are lucky to get an answer back. It will then take another day or two to get the part shipped.
    The Mighty machines are built like tanks, but when you need parts it's a bit of a problem.
  4. Likes rpseguin liked this post
  5. #63
    Jun 2006
    San Jose, CA
    619
    533
    57
    Quote Originally Posted by ranchak View Post
    Thatís got to be frustrating!
    Yeah! Iím impressed by them so far!
    Thanks!
    Good to know!
  6. #64
    Jun 2006
    San Jose, CA
    619
    533
    57
    Moved the VMC yesterday.
    The rigger, All Machinery Moving, was very good and I definitely recommend them!!
    They did a great job, were quick and friendly!
    As I knew Iíd have to do, I had to unbolt/remove the Z axis motor and cable track to get it under my garage door.
    I hope I didnít mess anything up in the process.
    I already lowered the Z axis down and put the spindle nose onto wood block.
  7. #65
    Jun 2006
    San Jose, CA
    619
    533
    57
    I got a little bit of free time and measured the backup battery voltage at 3.74V, which seems good to me.
    I may eventually make an additional NiMH 3 AA cell pack that clips on instead of that expensive pack.
    I tried a few experiments of running the machine off single phase (I donít have my RPC back up and running yet).
    I managed to get the control to power on, but I was getting a Y03 AMP. UNEQUIPPED
    which Iím hoping is just it complaining about lack of 3ph.
    I havenít yet tried jumpering one of the 1ph hot legs to be 2 of the 3ph input legs.
    What risks are there in doing this?
    Worth trying?
    I think it should be safe to do, but would love to hear feedback/ideas.
  8. #66
    Jan 2014
    Washington
    4,586
    838
    2488
    You need to go to the DIAG I/O screen to see the full alarm details. The Y03 alarm means that power has not been applied to the drive or the selector switch that ID's the drive on the bus is not correctly set.
    I'm guessing it will be the spindle drive that the control doesn't see. Since all 3 axes display on the screen, I suspect those drives are happy. When I first was trying my Mori on single phase, I disconnected the power cables to Y, Z, and the spindle, only leaving X connected. When I booted the control, it only displayed the X axis and the Y03 alarm details showed Y, Z and S as the axes not found.
    How many kW or HP is your spindle? I'm running a 5HP Mitsu spindle drive on single phase with zero issues. Still has the full power and factory accel/decel rates. Larger drives might not do so well.
    If you narrow down the trouble to the spindle drive, post what model the drive is. I'll see if I have any info on it and may be able to give further advice.
    My gut feel is that your S03 alarm is not related to missing a leg on the power. Usually that would be captured as a low bus voltage alarm.
  9. #67
    Jun 2006
    San Jose, CA
    619
    533
    57
    Thanks!
    10HP/7.5KW
    FR-SGJ-2-7.5K-BR
    BN420U075
  10. #68
    Jun 2006
    San Jose, CA
    619
    533
    57
    Spindle drive (Mitsubishi FREQROL FR-SGJ) says Un E7 after I press the On button on the control.
    I donít see any red LEDs in the rest of the control boxes or axes drives.
  11. #69
    Jun 2006
    San Jose, CA
    619
    533
    57
    Diag I/O screen:
  12. #70
    May 2019
    362
    98
    128
    I believe E7 means it is receiving an estop signal from the controller.....
    I would not recommend jumping 2 legs of incoming power!
    On edit: I just estopped my machine in between cycles and the drive showed E7
  13. Likes rpseguin liked this post
  14. #71
    May 2019
    362
    98
    128
    I haven’t yet tried jumpering one of the 1ph hot legs to be 2 of the 3ph input legs.
    Worth trying?
    Not a good idea, if you don't understand electronics and electricity enough to fully trace out the system to see if this will cause harm, you are playing with fire IMO. Don't risk burning up your new machine
  15. #72
    Jun 2006
    San Jose, CA
    619
    533
    57
    Quote Originally Posted by Hardplates View Post
    I did trace things out to the drives, but I donít know enough about what they are doing internally.
    That said, I would think that the most that would happen is having it detect 0V potential difference leg to leg where it might expect 3ph.
    I am going to look for docs on this FREQROL FR-SGJ spindle drive to see if theyíll accept 1ph input.
  16. #73
    Jan 2014
    Washington
    4,586
    838
    2488
    Diag I/O screen:
    My earlier thought is likely wrong based on what I see here. Since it is reporting XYZ on the DIAGN screen then the servo amp is not happy about something. I don't have any info on that drive, nor for the Freqrol spindle drive unit.
    Single phase operation may very well not be possible with the hardware you have. The MDS-A-SVJ servo drives and MDS-A-SPJ spindle drive (up to 5HP any way) will work on single phase.
    Early Fanuc AC drives could be faked to run on single phase but needed a jumper from one hot leg to the unconnected leg to fool a power loss detection problem. Whether or not your drive would be similar or not is unknown. An experiment could be costly. I don't think it would cause any harm, but if you proceed, it's at your risk.
  17. Likes rpseguin liked this post
  18. #74
    Jun 2006
    San Jose, CA
    619
    533
    57
    Thanks!
    So, I got my 25HP rotary phase converter wired up and spun it up and got the machine powered with 3ph power and all the drives came up and I am able to jog the axes and run the spindle.
    I may try the single phase experiments again at a later time, as it would be nice to not have to spin up and run the RPC.
    Now I need to fix the issues and learn how to use this control/machine properly.
    Issues:
    1. X axis limit switch needs fixing so I can home/reference the axes and actually run programs.
    2. How do I load tools into the carousel toolchanger?
    I can do manual toolchange with the button near the spindle, but when I go T2 M6 in the monitor or try in MDI, it doesnít do it.
    Iím wondering if itís related to #3 below.
    3. Looks like I have some kind of air leak in the manifold.
    YouTube
    Iím wondering if something got jiggled during rigging/transportation.
  19. #75
    Oct 2009
    Oregon
    4,193
    4499
    2131
    You'll have to home at least the Z axis to change a tool.
    Sometimes the tool call and M6 have to be on separate lines.
    If z is homed and you MDI T2-EOB-M6-EOB-INSERT and hit cycle start you should have a toolchange.
  20. Likes rpseguin liked this post
  21. #76
    Jun 2006
    San Jose, CA
    619
    533
    57
    Quote Originally Posted by Garwood View Post
    Thanks!
    That makes sense!
  22. #77
    Jun 2006
    San Jose, CA
    619
    533
    57
    Thanks!!
    That makes sense!
    Iíll do that when I power up next
  23. #78
    Jun 2006
    San Jose, CA
    619
    533
    57
    Thanks!
    Worked fine!
    Now I need to:
    -fill lubricant pump reservoir. I have Vactra #2 equivalent on hand, but not sure thatís best. I donít have the manual for the machine (Comet/Advanced VMC 520).
    -fix my X axis home/zero ref switch
    -fix leaky air in/near solenoid manifold
    (Leaks when power is on or off)
    -rotate control pendant to give more space between machines.
  24. Likes Garwood liked this post
  25. #79
    Jun 2006
    San Jose, CA
    619
    533
    57
    What way lube should I use for a Mighty Comet/Advanced VMC 520?
    I have Vactra #2 equivalent on hand, but not sure if thatís best.
    Thanks!
  26. #80
    Oct 2009
    Oregon
    4,193
    4499
    2131
    Vactra 2 is a pretty safe bet. Might dump the lube sump and clean the suction screen since your fixing stuff.
  27. Likes rpseguin liked this post
