01-10-2021, 11:31 AM #61
01-10-2021, 01:03 PM #62
My neighbor (Swiss shop) is selling a newer (2016) Mazak and barfeeder that they need to move to put in another Swiss machine. Look it up on Milwaukee Craigslist and see if it will do the job.
Here is a link.
Pete Deal liked this post
01-10-2021, 09:08 PM #63
CosmosK liked this post
01-11-2021, 10:38 AM #64
01-11-2021, 10:38 AM #65
Do you have a spindle probe on your Brother? If not, going with a 2 axis lathe and putting a little of the savings toward a probe for your Brother could be a good way to go. You can nail second op work with the probe in process.
Basic live tooling on a lathe is pretty limiting. You have already heard of the TS Takisawa that Yamazen stocks. They have sub with full C and almost 5" of Y. That is the way shops are going for increased lathe versatility. With one turret still simple to program too. Price is right due to the volume installed.
01-12-2021, 11:12 AM #66
01-12-2021, 11:22 AM #67
01-12-2021, 11:38 AM #68
01-12-2021, 12:30 PM #69
01-12-2021, 12:43 PM #70
Constant dousing with coolant I'd imagine would remove the grease from the rails. Fines getting into the wipers (although maybe less of those on a lathe). Parts dropping on rails. Those are the three reasons I don't like it.
01-12-2021, 01:46 PM #71
The below number is from a recent quote. This is before discounts. You should also ask if Titans' dicounts are still in effect.
MAIN FEATURES
- 20 hp high torque digital AC spindle motor
- Large 2" bar capacity
- High speed 6,000 rpm spindle
- High precision pre-tensioned X-axes double nut ball screw with electric torque limiter protection
- 12 station heavy duty servo controlled turret with 24 position indexing and (0.11 second) next station index
- Rigid 30-degree one piece cast iron slant bed
- Large 11.8" maximum turning diameter
- Widely spaced, high precision roller type linear motion guideways
- 20.0" maximum turning length
- Fast 1,417 ipm Z axis rapid traverse
- Full contouring C-Axis
- Milling, drilling and rigid tapping capabilities on both main spindle and rotary tools. 3 rotating tool holders included in standard tooling package
- 6,000 rpm, 5 hp, rotating tool spindle motor. Live tools can be mounted on all stations
- Y-Axis turret with 4.13” (±2.065”) total travel
- Bolt up chip conveyor design for easy access and removal of coolant tank
- FANUC 0i-T control with swiveling operator's panel
- Doosan EZ Guide i Conversational Programming
- Doosan Tool Load Monitoring System
LYNX 2100LYA with FANUC 0i-T control $111,500
01-12-2021, 02:05 PM #72
I know Doosan is Korean, but where are the machines and their components built?
01-13-2021, 08:40 AM #73
01-13-2021, 09:05 AM #74
01-13-2021, 09:54 AM #75
For me, not that much. Even the few times it did happen it usually falls clear and slams the chip conveyor belt. Like I said, we never really had a problem. The lube is constantly metered, the wipers - if maintained - do their job.
On box way lathes - most of the time the ways are exposed as well. As long as you change the wipers - and I do regularly on mine - there's no problem. Just sayin'..
01-13-2021, 12:02 PM #76
For very little (4%) more than that I got a quote with sub spindle. Doosan definitely came in as the most cost effective machine. With some of the best options
I was just worried about some things like the light weight of the machine and the fact that there were no way covers on what I thought were important surfaces. I was even able to see chips were getting into the blocks as the caps the used on the linear rails were slightly recessed and small fines can get stuck in there and dragged into the block. I see this being a problem over time.
If you never produce fine chips this will probably never be an issue.
01-13-2021, 12:14 PM #77
Can anyone give me advice on collet tooling? I need something. I keep seeing ads for Royal. Their accu-length system seems pretty sweet, but pricey, about 4k then 2-300 per collet. Anyone use those? Thanks
01-13-2021, 12:56 PM #78
01-13-2021, 05:27 PM #79
There are several offline packages that speak Mazatrol.
01-13-2021, 06:39 PM #80Can anyone give me advice on collet tooling? I need something. I keep seeing ads for Royal. Their accu-length system seems pretty sweet, but pricey, about 4k then 2-300 per collet. Anyone use those? Thanks
