Hey guys, I used these awesome gauges for measuring counterbore dia's at an old shop but I do not know what the actual name of that type of gauge is called and haven't had much luck searching online for them either. They were very similar to a regular bore gauge other than the gauge had two extra points of contact and the bottom of it was completely flat to sit in a counterbore. They came with these flat extensions for different sizes that had teeth on one side and then there was a pin and a spring that got screwed in that held the extensions flat to the bottom. Would then set the gauge using a micrometer set up on Gauge blocks to whatever diameter you were looking for. If you were to look at this gauge from a top view it would looks something similar to this --E With the middle stem of the E being the part associated with the dial at the top of the gauge and the other two parts of the E are the other two points of contact used to center it in the counter bore. If anyone knows what these might be called or has any idea what i'm trying to explain I would greatly appreciate it. I'm looking to get some ordered at the new shop that I'm at and nobody here has ever heard or seen of them.
