yes, board level schematic to help the person repair mine.
I have purchased 2 Mean Well QP-320F power supplies but neither of them made my WDT fault go away.
I tested both of them while connected to my control and had 10 to 54 Vac ripple on V1, V2 and V3 which I assume is why they would not work.
This is a linear supply? do you have electronic experience? Not sure what a schematic will do. That issue should take 10min to find. Just off the cuff, I would say a diode is tits up. No, I doubt the filter caps are your issue but that is where the experience comes in. Ripple is a function of load.
Did the old caps leak? Did you fix the board from that issue? Can I assume you used proper low ESR caps?
A few pics of the supply would be good. I don't know squat about what we are talking about. Just know it would take an experienced electrohead only minutes to figure it out. Might be worth some calls.
My vote would be to take it somewhere that fixes power supplies. You might have screwed yourself if you did not source the right caps. ESR is equivalent series resistance. General caps do not have low enough ESR the handle the high frequencies in an SMPS for very long. You buy ONLY the best and lowest ESR caps you can buy and the higher the temp rating, the better. 85C caps are inferior to 105C caps. Ripple is also a function of ESR.
You better vet your repair guy though. Many are just parts changers today. The right guy will find and fix that in short order. If it is multi voltage, you have to figure out how it is constructed and if ripple is evident on all voltages or not. That puts you on the path pretty quick.
What info are you looking for, board level schematics. I might have it but would take me a few days to look. There is an aftermarket unit that works you can get off eBay for about 150 of your interested in that I can find the part number
Notice
