brettallen59
- Aug 12, 2011
- Austin, Texas
Anyone know of a forum about machining using ceramic inserts?
Brett.....
Brett.....
Ceramic inserts are used to super finishing operations. Ceramics are harder than carbide but more fragile, so it will not be a good idea using them on interrupted cut,.
Yes, I totally did not anticipate success using Ceramics on pure Nickel. That's why it's been a year of fighting it using carbide until I finally decided to give it a shot....And I was totally blown away!The issue using carbide is the inability to break a chip. No matter which chip breaker, depth of cut or any combination failed to break a chip. After each pass I would spend time with wire cutters or tin snips cutting the chip up into manageable removable sections into the chip hopper. Spent more time pulling chips than I did cutting!With the insert I tried so far, the chip is very manageable and it breaks like a normal chip. I am also using coolant! It would take me two days of fighting the chips in order to complete a part. The part I cut with ceramics took 8 hours!I was hoping to find someone that has tried the Bidemics inserts and their experience.Thanks for everyone's input,Brett......
Actually, yes. I subscribe to the philosophy that sharp cutting edges which "Shear" and not "push" create less heat and reduce cutting forces out perform honed "stronger" inserts. That was my first "out of the box" effort. I used a Arno brand insert, which was the only insert we found to be successful at my last job turning a proprietary grade of aluminum for a computer housing. It made the best chip, but it was still not able to break it.Cutting on a Mazak QT450II-M, the T-Land insert was generating a 3% spindle load, whereas the non-T land was at 6%. I think I will reach out to the NTK people and see what they think about my application for their Bidemics line. Don't know if I can post links here but I'll try; http://www.ntkcuttingtools.com/product/insert_BIDEMICS_index.htmlThanks,Brett.....Have you tried any inserts for aluminum? Something with a wicked sharp edge, very high-lubricity coating, and very, very tight chip-breaker?One insert I'd be willing to try in that material - Walter makes an insert in WSM01? grade I think - with their "HIPIMS" PVD nano coating that blew me away. It comes in a positive insert, but the coating is extremely smooth. What you end up with is an insert with extremely low cutting forces.I'm not really trying to get you to reinvent the wheel, just a little perplexed that ceramic t-land inserts would perform well in commercially pure nickel.Would you happen to know the tensile-strength of the material by chance?
Greenleaf s new grade of ceramic is Xsytiin 1 it works very well in interrupted cutsWe highly used ceramic inserts for connecting rod turning bores with light feeds, high speeds and smooth(non intrupted cuts. NTK proved the best of ceramics back in the 70s to 90s. yes conn rods are hard but I forget now how hard...
Notice
