Looking for strategy when machining window out of a plate
Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Oct 2004
    Elyria Ohio
    1,814
    3423
    764
    Default Looking for strategy when machining window out of a plate
    So whenever we machine a window out of a plate, the inside part often gets in the way and can break the tool if you don't feedhold and physically remove the inside portion. If we are running "lights out" this is bad.
    Sometimes we will resort to machining the inside of a window area as a pocket so as to reduce inside portion to chips which are easily flushed out by flood coolant.
    Sometimes we will leave it attached by .01" or so and then just break it out and debur the edge to blend it in but that is not ideal and creates a lot of unnecessary work.
    Does anyone have a technique they would like to share?
    Sep 2014
    Minnesota
    190
    79
    117
    We do a lot of this type of work. 90% of the time we treat it as a pocket and turn it into chips. The rest of the time we run a bolt thru the window into the fixture to hold it in place till the rest of machining is done. It really depends on your material, cycle time, and qty though.
  3. Likes as9100d, Joe Miranda liked this post
    Apr 2019
    Arkansas
    886
    290
    327
    ---^ exactly what is needed.
    If its aluminum, we just HSM the material away and get on with life.
    Jun 2012
    Michigan
    4,750
    4355
    2884
    I've found that using TWO bolts in the center will guarantee it from spinning when you break thru on the perimeter. One bolt will work most of the time, but not every time.
    Jan 2007
    New Jersey
    956
    467
    472
    If it is steel, place a few strong magnets across the gap as the cutter goes around. Did this all the time, like how we did it with a wire EDM.
    Paul
    Jan 2014
    Washington
    4,685
    848
    2544
    I wonder how many times I wanted to take out of a programmers pay the costs of leaving loose slugs? I've seen broken tools, broken windows, damaged chip conveyors, etc. all from not restraining or cutting up slugs.
  8. Likes Joe Miranda, 2outof3 liked this post
  9. #7
    Jan 2014
    Oregon
    296
    52
    146
    2 bolts through it has always been my strategy. Agreed that in aluminum most of the time it is easier/faster to just turn it into chips.
  10. Likes Mtndew, Joe Miranda liked this post
  11. #8
    Sep 2002
    People's Republic
    3,356
    281
    2198
    You have to decide 'what' time is more valuable.
    feed hold traps the operator watching the machine
    mill to chip spends spindle time
    bolts ads operator time and machine time
    most CAM programs have 'tab' milling so it will leave any number of thin tabs of variable width and thickness
    This saves machine time and limits operator time to either filing the remainder of the tab off or twisting the slug out and then pressing go to finish mill
  12. Likes Joe Miranda, DieselMater86, lavrgs liked this post
  13. #9
    Jul 2008
    Milverton, Ontario, Canada
    642
    176
    287
    Depending on if its worth keeping the inside portion, ill z level down to leave say .05", then machine hold tabs, manually cut hold tabs out, then machine inside of pocket.
    But its gotta be worth the time.
    For really thin sheet metal\lexan type stuff, ill lay a backing plate down and do the tape\tape trick using krazy glue to hold the assembly together. Pretty slick.
  14. Likes Joe Miranda liked this post
  15. #10
    Feb 2008
    MI, USA
    812
    61
    317
    If the windows are small, or the slug is not worth salvage, make chips.
    Sometimes I am able to fixture plates that have big through features high enough off the table that the slugs fall safely to the table below (mostly aluminum, I don't want heavy steel slugs to do the same to the table)
    The only time I regularly don't do these is when running some large windows of tougher steel (4140, 304, and the like) when it is thicker (3/4+). In these cases, I often will rough out these kind of windows with 7/8 or 1" cobalt roughers. Yeah, the slow and steady type. With the kind of low RPM these go, I don't fear them getting ejected, so I just have an M0 afterward to pick it out.
    I generally only do the drill holes and bolts through method on parts that go on the horizontal. The chip conveyor doesn't appreciate 4lb chunks of sharp steel falling 3 feet down onto it.
  16. Likes Joe Miranda liked this post
  17. #11
    Feb 2013
    Idaho
    692
    145
    740
    I used to have a long running job out of 3/4" plate. I held down the slug with 6 1/2-13 Low Head Socket Screws... then I turned the slug into three Kurt style soft jaws. It was definitely slower than turning it into chips, but it made me happy every time I took a part off the mill.
  18. #12
    Feb 2005
    Akron, OH
    1,864
    289
    1397
    If it's a big window such that the drop is worth keeping and meaningful volume, a vacuum fixture will keep it in place nicely. You'd still want to onion skin it and then do the final cut-out towards the end of the program.
  19. Likes Joe Miranda liked this post
  20. #13
    Jun 2006
    Thunder Bay Canada
    1,818
    570
    305
    I recall being asked by a supervisor why we didn't stop our Whitney punch press to remove a sheet metal corner slug. Whitney taught us to just nibble the whole thing out if it was ten hits or less.
    Sort of like milling the whole cutout into chips as described by the OP.
  21. Likes Joe Miranda liked this post
  22. #14
    Feb 2004
    Staten Island NewYork USA
    3,764
    1106
    1801
    I don't think there is any one answer as it all depends on slug size and how critical the finish is, time allowed.
    A big window I'll let it drop away most of the time if not thick and heavy. Smaller windows...run a drill through to hog out and finish the pocket.
    If i want the drop, pretty large or parts I leave a small bit around to push out later.
    If not a big drop its all chips...
  23. Likes Joe Miranda liked this post
  24. #15
    Feb 2007
    Boston MA
    1,024
    371
    868
    The options above are all valid and often it comes down to the time to design/make a fixture (vaccum) vs cost to turn it into chips vs cost to install a bolt.
    Let me toss a couple other ideas into the mix that might hit a sweet spot on the cost/time equation:
    1) Drill a through hole in slug and use the *machine* to put the screw in. Make a hex driver tool with a magnet, then pre-load the cap screw into a close-fit hole on an unused part of the fixture. Grab your tool, move to your hole and run a tapping cycle to pop the cap screw into a threaded hole in the fixture. Pain in the ass to make the tool (you'll need a drill/driver clutch on there too) but it works when you dial it in and is fast.
    2) Have a spring-loaded captive pin below the slug. You compress the pin down when you push the part on the fixture. The machine runs a drill down on the top, and on the way up the pin (now free from the covering material) extends up into the hole. It doesn't hold it super-securely, but definitely stops it falling out or contacting the cutter.
    3) Similar to #1 but install some plastic or metal push rivets like those that hold on automotive bumpers. Simple custom tool and easy program cycle and you're good.
  25. Likes alexdobbie, Joe Miranda, mhajicek liked this post
  26. #16
    Oct 2004
    Elyria Ohio
    1,814
    3423
    764
    Thanks all -
  27. #17
    Feb 2008
    MI, USA
    812
    61
    317
    Quote Originally Posted by G00 Proto View Post
    That is a great idea! Next time I have large enough cutout, I'll make the bolt pattern the same as standard jaws!
    That is kind of brilliant.
  28. #18
    Jan 2019
    SWEDEN
    190
    56
    22
    Just thinking out loud here.
    What about, in the case of machining a square window in a plate, first remove enough material on one side so the material to be chopped off can move, then chop it off using conventional milling?
  29. #19
    Feb 2013
    Idaho
    692
    145
    740
    Quote Originally Posted by Tichy View Post
    It'll still occasionally come back and get tangled up with the cutter. It happens fast, and the results can be pretty bad to machines, parts and people.
    Back in the scary old days, we used to wait until the slug was just about to break free, then we would reach in there and push the slug away from the cutter with the handle of a dead blow hammer. Then when the program moved to the next window, we'd crawl in there and grab the slug. Keep in mind this was a 10 foot by 30 foot table and the parts were coming out of a full sheet of aluminum. Ah the good old days before machining was dangerous.
  30. Likes Mtndew liked this post
  31. #20
    Sep 2010
    Vancouver Canada
    935
    690
    335
    Waterjet the plate out, leaving .05" all around.
