atex57
Stainless
- Sep 6, 2006
- SW Wisconsin
I'm looking for a 1/8" or 3mm turn/groove tool holder and inserts. Depth at least .6" or 16mm deep.
This will be used on 1045 and 8620 steel mostly with a little 1018 and tool steels.
The primary application will be cutting grooves about .55" deep per side and about 2" wide with a radius in the corners.
Latheinserts.com has a holder and inserts that look like they would work, any recommendations? Feeds and speeds? Depth of cut?
Right now I am using an older Manchester dogbone style. The part I don't like is the insert is only grooved on the bottom and with a flat top so I worry about the insert tipping when it would get dull.
TIA Ed.
TIA Ed.
