Hey guys Im drilling some 7/8" holes, 3.5" deep in steel. Several thousand of them. Using kennametal KTFS carbide tip drills. The inserts are holding up fairly well, but have lost a few a little early with the center blowing out long before insert was worn. See attached pic. I hate loosing tools before they are fully worn out. What do you guys think is causing this? Any suggestions with speed/feed to reduce it?
This is on a Mazak lathe. Coolant through the tool, fairly low pressure but good flow and chips are getting out perfectly. Tool is straight and on center. Running 0.012"/rev and 1500 RPM. Kennametal reccomends something like 0.010-0.019 IPR feedrate. I am facing and then drilling (no spot drill). There is no tit left from facing. One died on entry and 2 more died deeper inside.
Any suggestions? How many holes should I expect from an insert? I need to buy another drill like this soon (around 1.050"), should I look at other brands? What do you guys reccomend?
