KristianSilva
- Nov 26, 2016
Hi,
I am currently working on bringing spline milling in house at the company I work for, we have a small Haas TM-1P that sits idle 80% of the time so we want to put it to good use and use it to spline all the shafts we manufacture.
However we are trying to do this for as little cost as possible, which is why we are trying to avoid using a Haas rotary head as they cost £10000 + £2000 for the 4th axis option. Another reason we are not wanting to spend this amount of money is that it is over-kill for what we need, we do not need 4th axis capability, we only need to be able to increment X number of degrees, cut a spline, index, cut a spline, index etc... it is not worth spending that much money on 4th axis capability that wont be used.
So my question is, what other options do we have for simple CNC rotary indexing? We were thinking that there may be a solution that allows us to set an increment size and then connect the indexer to the bank of M code relays and simply index by commanding an M code? Im curious to see if anyone else has done something similar? Surely there must be a solution to this problem as only simple incremental indexing is needed.
Any suggestions would be appreciated!
