Bluejeep
Hot Rolled
- Aug 3, 2006
- Cape Cod, Ma
I need to lower the pressure and volume of coolant in my machining center, would throttling it down to a light stream with a ball valve cause a problem with the coolant pump?
Better to plumb a bypass route round the pump, and throttle that, to keep the pump pumping a reasonably constant volume
I agree, if you choke it down and almost dead head the pump, there’s not enough volume flowing to keep it cool. Many pumps use what there pumping as a way to transfer heat out of the pump. Personally, I’d plumb a T fitting in, add a valve to that, and use that to lower pressure. If you have a valve near your coolant output (at the pump after the tee or up near the nozzle) that can be further fine tuned to get the result you want.
Notice
