M3/4 not possible
Results 1 to 12 of 12
    Dec 2014
    Kansas
    Default M3/4 not possible
    I've got a DMG machining center with a TNC426 controller. Today, in the middle of making a part that we had already made several runs on, our machine went to change tools and, after changing, gave me an error "M3/4 NOT POSSIBLE". I can clear the error but when I tried telling it to restart (either where it left off or starting fresh) it pops back up and the spindle doesn't move. After several attempts to start the program back up, I tried rebooting the controller. It rebooted successfully and went through all of startup just fine, but when I attempted to do a manual M3, it gives the same error message. Hoping someone out there can help me figure this out!
    May 2017
    Minnesota
    1,087
    1346
    735
    Sounds like a service call is in order.
    Oct 2010
    Dewees Texas
    2,401
    27
    657
    Older machine and needs the zero M03/M04?
    Jan 2017
    Oregon
    2,674
    474
    1896
    Can you M19?
    MDI a tool change?
    Way oil level ok?
    Air pressure ok?
    Sep 2002
    People's Republic
    3,356
    281
    2198
    If it isn't an actual failure all I can think of is that it doesn't think there is a tool in the spindle.
    Jul 2006
    Arizona
    4,616
    18498
    4340
    Quote Originally Posted by Scott Smith View Post
    Sounds like the spindle VFD might have died.
    Sep 2002
    People's Republic
    3,356
    281
    2198
    'Generally' that would result in a position error of some sort
    Apr 2005
    Beaverdam, Virginia
    7,478
    708
    3532
    Never worked on that controller. Are there any alarm codes on any of the drives inside the cabinet?
  9. Likes Philabuster liked this post
  10. #9
    Sep 2006
    Long Island, New York
    636
    239
    85
    Just shooting from the hip here: Does the spindle orient with a shot pin? If so are you getting a good signal from the switch?
  11. #10
    Sep 2006
    636
    239
    85
    Actually apply the same question to the gearbox (if it has one), is it all the way in hi or low? Good signal from the switch?
  12. #11
    Feb 2012
    1,381
    884
    1485
    When the spindle won't start after a tool change:
    - Check that the ATC is in home position: door is shut and signal is registering, arm is in home position, etc
    - Check the pull stud of the tool in the spindle. Swap out the tool and see what happens.
  13. Likes Philabuster, chucker liked this post
  14. #12
    Oct 2007
    SPAIN
    3,569
    2003
    1300
    1st and only post so far.
    I wonder if we'll ever get to know...
