M5x.5 tap drill size?
Page 1 of 2 12 LastLast
Results 1 to 20 of 26
    Jun 2017
    72
    7
    14
    Default M5x.5 tap drill size?
    Anyone know the drill size for the m5x.5 its not listened on any chart I've been able to find
    Jun 2015
    Colorado
    570
    1167
    230
    Good rule of thumb that works pretty well for metric taps is take the tap size and subtract the pitch to get the tap drill size. So a 4.5mm drill in your case.
    Sep 2018
    Ohio
    77
    20
    13
    Quote Originally Posted by Erstwhile View Post
    For a guide you can ...let's use a 1/4-20 for example. Take .250 and subtract depth per revolution which in this case is .05 (1÷20) . Take .250 - .050 gives you a drill size of .200
    Do the math on any tap size and will get you within .001 of what it calls for.
    Sent from my SM-G950U using Tapatalk
  4. Likes ChipSplitter liked this post
    Sep 2018
    Ohio
    77
    20
    13
    Quote Originally Posted by BugRobotics View Post
    Good rule of thumb that works pretty well is take the tap size and subtract the pitch to get the tap drill size. So a 4.5mm drill in your case.
    Exactly this. In less words
  6. Likes gustafson, Bobw liked this post
  7. #5
    Jan 2019
    Arizona
    950
    84
    347
    best and only way is to look up the Minor dias for that thread and use that. there is no other substitute,
  8. #6
    Sep 2018
    Ohio
    77
    20
    13
    Quote Originally Posted by Delw View Post
    Just curious... for just say a 1/4 20 2A you would use less than a .190?? I feel like I would be breaking alot of taps??
  9. #7
    Jan 2019
    Arizona
    950
    84
    347
    Quote Originally Posted by tobydbaker74 View Post
    I would hope not, considering the minor dia for a 1/4-20(which is a 2b not a 2a btw) is max.207- min.196
    where did you come up with that number?
  10. #8
    Jan 2019
    Arizona
    950
    84
    347
    oh forget it, you looked at the external thread data on a 1/4-20 thread and came up with your number which is a .1894 Max minor Dia.
    FYI there is a huge difference between external data on thread and internal data on a thread. This is why you have to pay attention to what your looking at,
  11. Likes tobydbaker74 liked this post
  12. #9
    Apr 2015
    AUSTRALIA
    739
    38
    165
    according to machinerys handbook
    M5 coarse ...drill 4.2mm recommended gives 81 percent engagement
    or 4.3 giving 71 percent engagement
    does not state the pitch though only coarse thread.
    if its fine metric fine then it no applicable to that.
    i just checked the chart i have P and N chart
    lists coarse as 5 x 0.8 so no good to you in regard to the above information
    need to keep looking, ring up the tap supplier to see maybe the best bet
  13. #10
    Jan 2019
    Arizona
    950
    84
    347
    m5 x0.5 6h is
    max minor 4.599 ie .1811
    min minor 4.459 ie .1756
    They got aps for phones and computers everywhere even free, or you can just type it up in a yahoo or google
  14. #11
    Sep 2018
    Ohio
    77
    20
    13
    Yes you are correct I'm getting old and looked at the wrong chart.
  15. #12
    Dec 2008
    New York
    10,343
    2681
    i believe thats for 75% thread and yes its commonly done. just look at tap drill chart, usually tap drill size is close to that rule of thumb. drill bits can easily drill oversize especially if badly sharpened. just saying 4.5mm drill "might" drill bigger than 4.5mm. fine threads got to watch for that even more
  16. Likes BugRobotics liked this post
  17. #13
    Mar 2001
    Switzerland
    2,582
    2569
    1147
    BugRobotics got it, see image from DC Swiss site- but I will second what Tom said about accurate drill size, you can lose a lot of thread if your drill goes oversize just a little at a fine pitch like that.
  18. Likes BugRobotics liked this post
  19. #14
    Jan 2005
    The Netherlands
    6,033
    292
    1625
    Quote Originally Posted by Screwmachine View Post
    Thats why some people call it hole size perhaps ??
    Peter
  20. #15
    Dec 2019
    Utah
    8
    I'm assuming this is for cut taps. How would this rule of thumb look for roll or form taps?
  21. #16
    Feb 2017
    98
    8
    32
    The wonderful world of metric threads. It doesn't just work for taps. Boring for an M80x2 thread? Ø78 will do just fine
  22. #17
    Jan 2014
    Washington
    5,188
    931
    2814
    Quote Originally Posted by tonymor View Post
    The wonderful world of metric threads. ......
    Same rule works for any 60 degree thread, metric or imperial. I haven't used a tap drill chart in 40+ years since learning this little tidbit.
  23. Likes metlmunchr liked this post
  24. #18
    Dec 2008
    New York
    10,343
    2681
    not only a badly sharpened drill but a drill bit that hit a hard spot of slag can get damaged and drill oversized holes.
    i have even seen carbide drill damaged drill holes .040" oversize before. usually its best to inspect parts and look at threads and see if internal threaded holes look ok or that look like a oversized drill was used. worst case is to have damaged drill with 60 minutes tool time left, drill hundreds if not 1000's of oversized holes on many many parts.
    most blow out holes and what better time than to look at threaded holes right after ? I never assume drilled holes is same size as drill bit from decades of experience.
  25. #19
    Feb 2005
    9,262
    14980
    11108
    Quote Originally Posted by Nibleswick View Post
    Pitch diameter plus a few thou.
  26. #20
    Nov 2004
    WI
    4,749
    518
    1105
    Take the tap size and subtract 1/2 the pitch.
    Check out the tap charts. The ones I checked all followed that formula
