In Machine (lathe) Electrical Raceway
Results 1 to 18 of 18
    Aug 2002
    West Unity, Ohio
    25,557
    5804
    8177
    Default In Machine (lathe) Electrical Raceway
    I need to replace an encoder warr that is in this mess.
    As you can see - the OEM raceway has released from it's host flat stock that is s'posed to give it some means of rigidity, and now it hangs down yonder.
    I'm not totally sure that it is even a problem for sure?
    Maybe it could be taken out, worshed up real good, and re-glued together?
    I have half-a-mind to put the new cable in it's own Liquitite and be done with it.
    Comments?
    Think Snow Eh!
    Ox
    May 2019
    576
    152
    224
    Zippy ties should do the trick no? That's how I've always fixed those stupid things that always seem to separate.
  3. Likes Donny Baker liked this post
    Aug 2002
    West Unity, Ohio
    25,557
    5804
    8177
    Hanging sideways like that?
    Or in a more vertical manner?
    I would Shirley think that _ that thin sheet of (what appears to be stainless shim stock) would shear ratt through any zip ties in short order.
    No???
    Think Snow Eh!
    Ox
    May 2019
    576
    152
    224
    Yup hanging horizonal. I used the big thick 1/4" or 3/8" wide ones used for large wiring and got them nice and tight and they held up just fine. Could always put a rubber softener under them too.
    Aug 2002
    West Unity, Ohio
    25,557
    5804
    8177
    I don't understand "Big Thick 1/4 or 3/8 wide ones".
    You understand that one end of this moves back/forth & up/down all day/night - right?
    Think Snow Eh!
    Ox
    May 2019
    576
    152
    224
    The big cable ties that are about 3' long and anywhere from 1/4" to 3/8" wide. The pic isn't of a horizontal one but it is on a slant bed img_20200123_182455826.jpg
  8. Likes Ox liked this post
  9. #7
    Aug 2002
    West Unity, Ohio
    25,557
    5804
    8177
    Well, I'll give it a go.
    Think Snow Eh!
    Ox
  10. #8
    Dec 2012
    Se Ma USA
    1,598
    125
    889
    I used some .250 OD polyurethane tubing to tie up the cables thingies that go to sub spindle. They rubbed on the housing on transfer before I did that. Tough to cut that stuff.
  11. #9
    Oct 2005
    16,137
    Quote Originally Posted by Hardplates View Post
    Yup, I use them to hold the mudflaps under my truck in the winter time, work great.
    BTW Panduit makes stainless tye-wraps, fairly wide, and a very shallow belt buckle style end.
  12. Likes Hardplates liked this post
  13. #10
    Aug 2002
    West Unity, Ohio
    25,557
    5804
    8177
    Well, I've prolly got $20 werth of 3/8 zip ties on that raceway now, and - I gotta say - it seems much more better than I would have expected!
    I have enough on there that maybe they won't feel the need to shear off so much either. (???)
    Now of course the top 2/3 of the raceway is empty - thank you to gravity and all the pro's and con's associated with such, and while the OEM cable is burried and twisted in amongst all that shtuff, I sent a section of 6 gauge warr through there, and it came out the other end on the 2nd try! So I think I'll try to pull the new cable up through there tomorrow. I have fish tape, but in this case - I think the 6g will be more better.... IDK why, but ...
    I patched this cable >10 yrs ago fer sure, and it's been fine ever since, but it's been fighting me this week,and I've gone through ten 3.2A fuses this week, so I have a cable coming from TIE and 10 more fuses coming from Galco. (I hope they made today's truck!)
    I am down at this point....
    Think Snow Eh!
    Ox
  14. Likes Hardplates, wheelieking71 liked this post
  15. #11
    Jun 2012
    Michigan, USA
    24
    Yep, I've been running the zip-tye trick on the Hardinge Gortubes(wireways) for almost a decade.
  16. #12
    Oct 2005
    16,137
    Use a proper tye wrap gun, and set it to "max." for the big ones.
    Pulls them up tite like vice grips.
  17. #13
    Aug 2002
    West Unity, Ohio
    25,557
    5804
    8177
    $400 and NDA fees - this machine is now Back in Business Again.
    The 20th Century's MVP Died on this date in 1965 @ 90 yr old
    Ox
  18. Likes cnctoolcat liked this post
  19. #14
    May 2019
    576
    152
    224
    Ox
    I'm not gonna lie, I was a little disappointed when I clicked on the link and it didn't go to a video of the old girl doin the business…...
  20. #15
    Oct 2005
    16,137
    Ox
    For some zip ties ?
    You shopping at NAPA again ?
  21. #16
    Aug 2002
    West Unity, Ohio
    25,557
    5804
    8177
    Encoder cable.
    Old Gurl Dooin' Business
    Ox
  22. #17
    May 2019
    576
    152
    224
    Encoder cable.
    Ox
    They sell those at NAPA?
  23. #18
    Oct 2005
    16,137
    Ask for an "F-150 wiring harness, 1996".
