Swiss lathe.
I am looking for recommendations on what machine type would work best for machining 304 stainless forgings into 20" rings.
Swiss lathe.
Welcome to the Jungle! Don't worry about the shitposts, it's just a little ritual they have here. What's happened is that you posted a question with little information, that's blood in the water for this lot.
Tell us more about the rings and the forgings. Are the profiles complex or simple? O-ring grooves? Surface finish and accuracy requirements? A lot of metal coming off the forgings, or near-net?
That info will help us help you. A simple ring could be a job for a manual vertical turning lathe (VTL), complex profiles are more easily done on a CNC version. If drilling hole patterns or other features, a Mill-Turn Center might be ideal, but much more spendy.
Another tip - an accurate and descriptive "title" for your new thread is mandatory, otherwise people can ignore or even remove a poorly-titled thread. For this one: "Need machine recommendation for turning 20" stainless rings" would work better.
Notice
