Machine Shop Layout - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #21
    Nov 2014
    Colorado
    2,803
    3315
    760
    Quote Originally Posted by gregormarwick View Post
    We currently have a layout similar to 1, with lathes in line end to end. Seemed like a reasonable idea at the time for crane access and operator visibility etc.
    It's a really bad setup. Can't run long bars up the spindle because the next machine is in the way, awkward to drive in/out with the chip bin, limited room to remove the conveyor because it slides out the end of the lathe etc.
    Angled would be my preference now for lathes.
    I was wondering about efficiency of diagonal layout as well, pros and cons .
    Maybe a useful compromise for OP also ?
    Wondering under what situations one would not use a diagonal layout ?
  2. #22
    Aug 2012
    New Jersey
    82
    20
    25
    I think diagonal would be good for smaller parts, but our operators hate loading large parts on a horizontal lathe with an overhead crane that is not square to the machine.
  3. #23
    Oct 2019
    Utah
    First off I would like to thank every one of you. I didn't think I would even get a response. Once you flow map # 2 it definitely looks cleaner on paper. I feel issuing material at set up, storing it behind the machine and having it pre-cut is less movement. All of our bars are pre-cut to 48" from the supplier. The largest bar we will ever run is 3" OD. We are a high volume of 95% aluminum shop. My vision is to have one operator run 2-4 machines at a time. We have about an 80%+ yield on 90% of our parts.
    Again, thank you
    Below are some quickly thrown together flow charts:
  4. #24
    Oct 2019
    Utah
  5. #25
    Oct 2007
    SPAIN
    3,382
    1869
    1226
    For high volume and multi manning, the best layout I have used is the attached.
    It takes a bit more space, but it also allows one operator to keep an eye on the other machines while the other operator disappears (toilet, smoke, phone, wander around - delete as applicable )
    It also makes everything visible - nowhere to hide...
