Machining 316, never done it before
Djstorm100
Cast Iron
Jul 26, 2014
Richmond
Most of what I do is in non-ferrous materials. I have a customer down the road that needs me to put 3" holes in 1" thick 316SS.
I haven not machine 316, so I start playing around with CAM to get a idea of how long it will take. I have 234 of these to do.
Cutters I'm looking at are a rougher and then finisher.
Rougher
Helical Tool 5 flute
-or-
Helical Tool 7 flute
then a 5 or 7 flute finisher.
If I was to run 7 flute rougher. Helical's data for the 7 flute are as follows: 265 SFM, up to %20 ADOC, 0.0036 Chip load @ 75-98 HRB
265 SFM (2025rpm) on a 1/2" cutter @ 0.100 WOC, chip load at 0.0038 (W/ chip thinning,actual chip is 0.003).
This equals out to be 52.88 ipm and yield 5 minute cycle time. This is to be done on a new Haas vf2ss 12k spindle.
Is this too aggressive in 316 with a Haas? Possible damage going around this much (repeated movements), plan is to do 3 parts at a time.
Plan would be to helical down and HSM strategy seen below.
Again, I never cut the stuff and looking for advice on the matter. Thanks in advance.
I much prefer predrilling to helical entry for just about any through holes.
316 is fine, just take a real chip and watch your SFM.
Rougher
-or-
Why waste your time with Cam, you have a haas which has a g13 code, one of the best features ever.
drill a hole bigger than your endmill then us g13 I(smaller than your hole size) k (finish size for rough tool) Q (stock removal) D (tool offset) F (feed rate)
for example rough tool
G01 Z-0.3 F50.0
G01 Z-0.3 I0.250 K1.450 Q0.050 D1 F25.0
G00 Z0.2
repeat for depths till through
G01 Z-0.6 F50.0
G01 Z-0.6 I0.250 K1.450 Q0.050 D1 F25.0
G00 Z0.2
then your finish tool
G01 Z-1.050 F50.0
G13 Z-1.050 I1.400 K1.5 Q0.015 D2 F25.0
G00 Z0.2
G01 Z-1.050 F50.0
G13 Z-1.050 I1.5 D2 F25.0 (SPRING PASS)
adjust for your own speeds and feeds and depths.
Personally I would cut all in one shot depth wise (and have) on rougher and finisher.
316 cuts nice.
if you need to cut in short depths then use a 4 or 5 flute EM with a .030 rad or even a .050 rad your endmills wont burn out as fast.
finish with a 5 or 7 flute will give awsum finishes.
Helix down isn't a great idea IMO. Drills are the most capable tools in the crib, in context of MRR. Drill-drop Endmill in hole and Helix out (not down).
As Delw said G13-12 is pretty much the best thing Gene ever offered. Super easy canned cycle. But if you need to, you can add a K value to the G13 to helix down AND out, but that's gay. No offense intended.
R
R
Heres the haas page for the code
G12 Circular Pocket Milling CW / G13 Circular Pocket Millin...
G12 Circular Pocket Milling CW / G13 Circular Pocket Milling CCW (Group 00)
These G-codes mill circular shapes. They are different only in that G12 uses a clockwise direction and G13 uses a counterclockwise direction. Both G-codes use the default XY circular plane (G17) and imply the use of G42 (cutter compensation) for G12 and G41 for G13. G12 and G13 are non-modal.
* D - Tool radius or diameter selection**
F - Feedrate
I - Radius of first circle (or finish if no K). I value must be greater than Tool Radius, but less than K value.
* K - Radius of finished circle (if specified)
* L - Loop count for repeating deeper cuts
* Q - Radius increment, or stepover (must be used with K)
Z - Depth of cut or increment
*indicates optional
**To get the programmed circle diameter, the control uses the selected D code tool size. To program tool centerline select D0.
NOTE Specify D00 if you do not want to use cutter compensation. If you do not specify a D value in the G12 / G13 block, the control uses the last commanded D value, even if it was previously canceled with a G40 .
Rapid-position the tool to the center of the circle. To remove all the material inside the circle, use I and Q values less than the tool diameter and a K value equal to the circle radius. To cut a circle radius only, use an I value set to the radius and no K or Q value.
O60121(SAMPLE G12 AND G13) ;
(G54 X0 Y0 is center of first pocket) ;
(Z0 is on top of the part) ;
(T1 is a .25 in. dia endmill) ;
(BEGIN PREPARATION BLOCKS) ;
T1 M06 (Select tool 1) ;
G00 G90 G40 G49 G54 (Safe startup) ;
G00 G54 X0 Y0 (Rapid to 1st position) ;
S1000 M03 (Spindle on CW) ;
G43 H01 Z0.1 (Tool offset 1 on) ;
M08 (Coolant on) ;
(BEGIN CUTTING BLOCKS) ;
G12 I0.75 F10. Z-1.2 D01 (Finish pocket CW) ;
G00 Z0.1 (Retract) ;
X5.(Move to center of next pocket) ;
G12 I0.3 K1.5 Q1. F10. Z-1.2 D01 ;
(Rough & finish CW) ;
X10.(Move to center of next pocket) ;
G13 I1.5 F10. Z-1.2 D01 (Finish CCW) ;
X15. (Move to center of the last pocket) ;
G13 I0.3 K1.5 Q0.3 F10. Z-1.2 D01 ;
(Rough & finish CCW) ;
(BEGIN COMPLETION BLOCKS) ;
G00 Z0.1 M09 (Rapid retract, Coolant off) ;
G53 G49 Z0 M05 (Z home, Spindle off) ;
G53 Y0 (Y home) ;
M30 (End program) ;
Circular Pocket Milling, G12 Clockwise shown: [1] I only, [2] I, K and Q only.
These G codes assume cutter compensation, so you do not need to program G41 or G42 in the program block. However, you must include a D offset number, for cutter radius or diameter, to adjust the circle diameter.
These program examples show the G12 and G13 format, and the different ways that you can write these programs.
Single Pass: Use I only.
Applications: One-pass counter boring; rough and finish pocketing of smaller holes, ID cutting of O-ring grooves.
Multiple Pass: Use I, K, and Q.
Applications: Multiple-pass counter boring; rough and finish pocketing of large holes with cutter overlap.
Multiple Z-Depth Pass: Using I only, or I, K, and Q (G91 and L may also be used).
Applications: Deep rough and finish pocketing.
The previous figures show the tool path during the pocket milling G-codes.
Example G13 multiple-pass using I, K, Q, L, and G91:
This program uses G91 and an L count of 4, so this cycle will execute a total of four times. The Z depth increment is 0.500. This is multiplied by the L count, making the total depth of this hole 2.000.
The G91 and L count can also be used in a G13I only line.
O60131 (G13 G91 CCW EXAMPLE) ;
(G54 X0 Y0 is center of 1st pocket) ;
(T1 is a 0.5 in. dia endmill) ;
G43 H01 Z0.1 (Activate tool offset 1) ;
M08 (Coolant on) ;
G13 G91 Z-.5 I.400 K2.0 Q.400 L4 D01 F20. ;
G00 G90 Z0.1 M09 (Rapid retract, coolant off) ;
G53 G49 Z0 M05 (Z home, spindle off) ;
G53 Y0 (Y home) ;
M30 (End program) ;
Definitely pre-drill and drop in the hole and go full depth if possible with a smaller radial engagement. You will get way better tool life and overall, your cycle time should still be shorter even with a tool change. I don't even think you need rougher/finisher depending on the finish needed. Should still get a great finish just drilling and then taking to size with a 5 flute. I haven't used a 7, so can't speak to that. The chip-breakers from Maritool have worked well for me in 304. I think the variable flute is the way to go.
1/2 Variable 5 Flute End Mill with Chip Breaker .750 LOC .030 Corner Chamfer MariTool
Do you have the High Speed Machining option?
If ya don't it's not gonna work to use an HSM strategy.
A Haas will top out at about 100 ipm without it.
Thing is the SFM will be low enough with stainless that you'd need to get down to like 5% radial before you're hitting 100ipm+ in feed rate.
Possibly. But, if he uses a 6 flute EM with higher SFM due to engagement angle plus radial chip thinning..... he might get there.
IDK, glad it's not my problem right now. :popcorn:
Good lord children. HSM techniques aren't really the answer here anyway. I know HSM is the new black, but it's a hole.
R
I agree with the others...put a hole in it first.
Those 7 flute Helical EMs you linked to are awesome. We're machining 17-4 and 13-8 PH with them right now and they are making quick work of it. Your numbers are pretty close, but I'm thinking you could squeeze 300 SFM out of it and maybe a bit more out of the feed then, also.
Looking at drills now with thru spindle coolant and peck it. If I'm using a 1/2" end mill, use a 13mm drill to give added diameter clearance?
Doesn't leave much clearance but you could make it work. I wouldn't hesitate to go a little bigger...9/16 or 14MM maybe.
And 1" isn't much to go through, even on a Haas. Find a nice carbide drill with TSC and you shouldn't have to peck it.
