Machining 316, never done it before - Page 2
Results 21 to 40 of 43
  1. #21
    Sep 2017
    Wisconsin
    982
    228
    628
    If you've got TSC then no need to peck. I like to keep the drill in the cut where I can.
  2. Likes as9100d, empwoer liked this post
  3. #22
    May 2016
    Ohio
    596
    171
    194
    I will throw my hat in this ring. I sell both Helical and Gorilla Mill. The Gorilla Mill is suggested to run 500 SFM 70 IPM with a .100" stepover for a 1/2" tool. Hit me up if you need a source. FYI Gorilla Mill is running a buy 4 get 1 free promo till the end of the month.
    I would pop a 5/8" indexable drill to depth and start an HSM path. If you go solid don't peck it is not a very deep hole compared to the drill diameter.
  4. #23
    May 2019
    Michigan
    1,517
    435
    707
    Quote Originally Posted by Shop Supply Guru View Post
    Watts the price difference between Helical and Gorilla?
  5. #24
    May 2016
    Ohio
    596
    171
    194
    Gorilla vs. Helical is pretty close across the board. If you picked ten random items and compared them I bet it would even out. I will say this they don't price similar series the same. One will be a lot cheaper than the other on similar products. Can't explain that....
    For this application a
    Helical 1/2" 1-1/4" flute length 7 fluter is $70.00 for Aplus and $81.40 for Tplus (which I bet would be better for 316)
    Gorilla Mill 1/2" 1-1/4" flute length 7 fluter is $75.59. The Gorilla Mill GMS2 coating is a step up from Aplus. Helical doesn't really share what's in their new Tplus coating so I am not sure how it compares but my guess is it is close to the GMS2 which is what Gorilla calls their Balzers AlCrN special mix.
  6. #25
    Jul 2014
    Virginia
    285
    108
    25
    This drill be ok? https://www.mscdirect.com/product/details/61704508
    Yes, I'm flying blind here. lol
    I do sincerely appreicate the help.
  7. #26
    May 2016
    Ohio
    596
    171
    194
    Dj don’t buy it from MSC whatever you do. I can sell you a Walter brand for half of that. I’m sure a local supplier to you could do the same.
  8. #27
    Apr 2010
    Illinois
    55
    69
    16
    My vote is on pre drill too. 316 is one material that has had me frustrated. Good quality carbide endmills worked the best. Full depth, 5–7% radial engagement. Tried indexable endmills and that was a joke.
  9. #28
    Nov 2013
    Utah
    4,897
    1295
    2769
    Quote Originally Posted by ChipSplitter View Post
    Ever try running a 1/2" EM 1.625" doc at full slot in 4140 PH ?
    Didn't think so.
    I'm not stupid, so no, I never tried that. You HSM folks that think it's going to cure world hunger are fools. It's great, I use Trochoidal paths a lot. But I cod finish this job faster than 5 minutes a part without it.
    OP the solid drill you posted from MSC is redonculously over priced. Why not use an Indexable Insert Drill? You don't need huge HP for them, your only going 1" deep. I could literally put a 2" hole in plate in maybe 30 seconds (including toolchange). Another .5" per side, with an Endmill in another 60 seconds-maybe 1.5 minutes.
    OR use HSM with the other youtubers, spend an hour getting code to the Machine. And spending what 4.15 (Mastercam) minutes Roughing and Finishing from a small hole.
    R
  10. Likes Shop Supply Guru liked this post
  11. #29
    May 2016
    Ohio
    596
    171
    194
    R
    A lot of customers especially ones a budget don't want to spend on indexable tool and that is where HSM/ Trochoidal whatever we want to call it helps. But I agree the bigger the tool the better. Also if you don't have a 2" or 1.5" flat bottom indexable drill it's time to get one as it makes much faster work and uses less tool in the long run..... of course then I sell less endmills
  12. Likes litlerob1 liked this post
  13. #30
    Nov 2013
    Utah
    4,897
    1295
    2769
    I'm still trying to figure out why people think Drilling a "hole" might be better with a Tool other than a Drill. Drills are-in fact- provably-indisputably the most effective metal removal Tool there is. Second is a Turning Centre.
    R
  14. Likes SIM liked this post
  15. #31
    May 2019
    Michigan
    1,517
    435
    707
    R
    I never said you have to use HSM.
    On this job he might do better with a heavy stepover.
    But, I have had times where HSM ended up saving the day, (i.e. long overhangs, limited fixturing, difficult material, etc., etc.).
    You can bitch about it all you want, I don't care.
    It's another tool in the bag......
  16. Likes empwoer liked this post
  17. #32
    Mar 2015
    Michigan
    426
    95
    146
    R
    I'm with you, but I'm gonna play devil's advocate here. OP has a Haas SS and runs mostly non-ferrous. Good recipe for "cutting corners" is all I'm saying.
  18. #33
    Nov 2013
    Utah
    4,897
    1295
    2769
    Hey Noob. Take it easy. I don't give 2 fucks what you do. But people who consistently tout HSM (like you), seem to have tunnel vision. It's not great for minor bumps or toothpaste. You shouldn't use it in your Spaghetti. You can't replace Gasoline with it.
    R
  19. #34
    May 2019
    Michigan
    1,517
    435
    707
    R
    Did I say that?
    I never implied that it's good for everything........ or even most things.
    All I said was it can be useful if a heavier stepover doesn't work well (rigidity, material, etc.)
    I don't use it unless I have to. THEN it's nice.
  20. Likes litlerob1, empwoer liked this post
  21. #35
    Sep 2017
    Wisconsin
    982
    228
    628
    Go on eBay and pick up a nice used Sumitomo SMD series inserted drill body and some inserts. It'll cost you half what that drill does from MSC. I love their split tip geometry for stainless and other "tough" metals, and they also make corner-chamfered (for hard steel or cast iron) and flat bottom inserts.
  22. #36
    Feb 2004
    Staten Island NewYork USA
    3,851
    1148
    1892
    R
    Its a hole, drill it as big as you can and interpolate the rest to size.
    What size hole can you drill?
    Well for a couple hundred pieces I would waste my money on indexables drill unless you have one or feel its a size worth buying for future work. They are one size for one hole size, body and inserts are pricey.
    Carbide drill...eh. Its as good as the tip lasts.
    HSS drill....if you have one, go for it.
    If you going to put cash down for a tool my money is on a Spade drill. Nice short size, 1-1/2" or so will pop a nice starting hole in 316SS in short time. Plus the body can be used for several other size inserts/blades and you can buy them as singles or buy several...not the indexable 10 packs
    Put the biggest hole in you can, then mill. If you wanna play with pockets cycles and HSM go for it...but start with BIGgest Hole you can.
  23. #37
    Dec 2008
    New York
    10,353
    2687
    316 SS if it has relatively large hard spots of slag in it will use up tooling 10x to 100x faster than normal. big difference if you got "cheap" SS with hard spots
    in general a harder metal you have to take less depth and width of cut cause of cutter vibration limits, just saying 1/2" dia end mill at 1" depth in SS good luck with that trying to do a 5 min cycle time, 7 cubic inches SS turned into chips or 1.4 cub inch per min at 0.3 cub in per hp per min thats about 4.7hp needed, thats a lot of hp and cutting force on a 1/2" dia end mill
    3" dia hole in 316 SS would take about if
    0.2 cubic in per hp per min
    30 sfpm so 38 rpm at 0.6 ipm feed need about 21hp
    if softer at 0.4 cubic in per hp per min about 10.8hp needed
    carbide insert drill 3" dia
    200 sfpm , 255rpm at 4.1 ipm feed about 72hp needed..... got to watch big carbide drills, they need a lot of hp
    abrasive wear dont be surprised tool dull in less than 10 minutes
  24. Likes cyanidekid liked this post
  25. #38
    May 2019
    Michigan
    1,517
    435
    707
    Quote Originally Posted by DMF_TomB View Post
    Where's the period key?
  26. #39
    Sep 2018
    624
    1038
    300
    Quote Originally Posted by Djstorm100 View Post
    Looking at drills now with thru spindle coolant and peck it. If I'm using a 1/2" end mill, use a 13mm drill to give added diameter clearance?
    dont peck, especially with TSC.
  27. #40
    Jul 2014
    Virginia
    285
    108
    25
    Customer contacted me and stated its 316L, not 316. Seems like"L" in the stainless means low carbon and does not affect machining much. It's for the most part meant to reduce sensitivity when welding or something like that. I could be wrong and probably am. If not low carbon, only other thing could mean is lead.
    If these parts happen to be cast, is there any precaution to know about with cutting cast material?
    I know some companies do not like to machine cast iron because of clean up or the dust getting in to places it should not (linear guides and lungs for example). Not sure if this is a aspect of it being cast or nature of iron.
