cmccull166
Hot Rolled
- Mar 29, 2013
- NW Pa
What miserable material to machine this is 2018... WTH !!!.I remember what we called jig plate in the 90's it was crap material to machine but Blanchard ground somewhat flat until you ran a slot thru it..and not flat any longer.
Mic 6 same crap with a bigger price tag and a fancier brochure.
That being said, I started this plate today there is an oval spiraling inward toward the center of the plate 1 mm wide .047 deep
approximately 30 Feet worth...
Using Harvey tool feeds .016 deep at 90 sf (10,000 rpm machine)made 3 inches before it broke.
It's obvious it doesn't cut it just burns thru (seeing the burrs)until the tool fails.
Tool 2 .01 deep 5 ipr 14 inches.
SO...
I put a 45 degree included 2 flute endmill in .019 deep 9900 rpm 6 ipr pressed go and Left
..I dont expect this to have a happy ending!
I'm sure Monday I will be calling the customer 6061 T6 or this part wont happen.
If any body has a suggestion Im all ears..
but the bottom line this material is crap and if I can save one person from banging their head on a bench ...i have been successful...
SO...
