I don’t machine Delrin very often, but I injection mold the stuff. A couple pertinent observations:
Delrin is polymerized formaldehyde. If you get it hot enough, it will break down and release formaldehyde gas. Very irritating to the eyes and nose.
I don’t know if you can get Delrin hot enough from machining operations to have it catch fire, but be aware that it burns with an invisible flame. If you see a piece that is foaming like a wet Alka-Seltzer, it is actually burning. It will eventually be entirely consumed, leaving only a little white powder residue. We see this effect when we clean mold components with a propane torch.
Delrin has a very low rate of water absorption, and is resistant to most oils, so coolant shouldn’t hurt anything, and would help with the gas and fire issues if doing very aggressive machining. That being said, the few times I’ve had to machine it, I’ve done it dry with no problems, but I wasn’t doing production.
Delrin, like most plastics has a much greater coefficient of thermal expansion than steel, so temperature must be closely maintained if tight tolerances need to be held. Also, Delrin is a crystalline material, and if not fully polymerized, heat can cause additional molecular cross linking, which will result in shrinkage. This shouldn’t be a problem with stock sold for machining applications, but could come back to bite you if doing secondary machining on injection molded components. The standard way to check for potential post molding shrinkage is to place the part in an oven at about 200*F for an hour, or an hour per inch of cross section after the material has come up to temperature, allow to cool, and recheck the dimensions. If it’s smaller, the original stock wasn’t fully cross linked. This same oven schedule can be used to normalize stock before machining if need be.
[FONT="]Dennis[/FONT]
