Hi lastrada:
Do you know what kind of foam it is?
There are a lot of different foams with a lot of different properties, so it's worthwhile to know what you're up against.
Also you will need to find out if it's open cell or closed cell foam, and how you manage it will depend on what it is.
I assume you don't get to pick what material...if you did, I'd recommend considering a product called Renshape.
It's used to make foundry patterns and mills like a dream but makes a helluva lot of dust..
It's also more rigid and dimensionally stable than foams tend to be and holds detail better.
Last, you might need to get a cold air gun or knock together an air blast nozzle...if you just flood cool it you're gonna make one helluva mess, and if you run it dry you might end up with a big melty blob on the end of your cutter.
There are lots of foams that can be cut dry at reasonable feedrates but not all of them.
You might also need to bodge together a vacuum system to suck up the crap as you make it...if you don't your co-workers may never forgive you.
The very last point; if the material turns out to be abrasive enough to be a problem, you could look into PCD cutters or diamond coated cutters like the guys who cut graphite EDM electrodes use.
Cheers
Marcus
