Machining a Gates Poly Chain GT2 Sprocket
Page 1 of 2 12 LastLast
Results 1 to 20 of 29
    Feb 2009
    Maryland
    175
    25
    25
    Default Machining a Gates Poly Chain GT2 Sprocket
    Hi guys. I need to machine the tooth profile for a Gates Poly Chain GT2 sprocket, but I can't find the exact tooth profile anywhere. I think this was patented by Gates, so the tooth profile should be public information. This is for a prototype sprocket (quantity of 1).
    I tried the Gates web site, but their CAD models say that the tooth profile is just an approximation, and shouldn't be used in production.
    Does anyone know where I can get the tooth profile?
    Sep 2018
    Michigan
    177
    33
    94
    This Appears to be the patent. They have been intentionally vague in the patent to help protect their IP. If you want to know the exact profile you are going to have to buy a belt and layout the tooth profile as best you can.
    https://patentimages.storage.googlea.../US8070634.pdf
    There is some more info on it on page 101 in the pdf below.
    https://assets.gates.com/content/dam...17595_2011.pdf
    Dec 2012
    OHIO
    258
    251
    217
    Can you just by a blank from CMT, and machine it to suit your needs??
    Feb 2009
    Maryland
    175
    25
    25
    Quote Originally Posted by TheBigLebowski View Post
    Thank you very much.
    Yes, the patent appears to describe the high level mathematics behind the tooth shape. But not the specific sizes of teeth chosen by Gates. Argh!
    Feb 2009
    Maryland
    175
    25
    25
    Quote Originally Posted by cpifer3 View Post
    Maybe. I will contact them. Good idea! It may be easier for them to just make it for me. I only need 1.
    Jon
    May 2002
    South Central PA
    14,667
    2874
    4400
    What size GT2? 8mm GT2 will run on a 8mm HTD pulley, not sure if there are design differences but they do work in practice, the larger sizes are different for certain.
    My old Gearotic has GT2 5mm and 8mm, a new version might have the larger ones now that the patent has expired
    Apr 2013
    341
    7
    153
    FWIW,
    I've reverse engineered similar profiles scanning the part on a basic 1200dpi flat bed scanner. Import into cad sketch environment, take relevant measurements from actual part. Create an accurate single tooth profile, polar array, make solid and CAM it.
    Jul 2006
    Hillsboro, New Hampshire
    14,285
    3128
    9507
    If I was doing this work, I'd want a sample pulley in as close a size to the one I wanted to make as possible. It's the pulley tooth profile that matters here, not the belt (which has a dynamic change of shape relative to the pulley).
  9. Likes Garwood, Ox, Pete Deal liked this post
  10. #9
    Feb 2009
    Maryland
    175
    25
    25
    Quote Originally Posted by Mud View Post
    The belt is a Gates Poly Chain GT Carbon, with 8 mm pitch. Gates specifically says that this belt needs to run on a Poly Chain GT2 sprocket, and cannot use an HTD sprocket or a Poly Grip sprocket (very confusing that "Poly Chain" and "Poly Grip" are different products).
  11. #10
    Feb 2009
    Maryland
    175
    25
    25
    Quote Originally Posted by Wsurfer View Post
    FWIW,
    These are both good ideas.
    I think the belt tooth is intentionally a different shape from the sprocket gully (they are not mirrors of each other).
    So I could buy a Gates sprocket of the appropriate size, and then scan that sprocket to CAD.
  12. #11
    Oct 2009
    Oregon
    6,589
    7026
    3897
    You can reverse engineer an existing sprocket with a decent set of calipers, radius gages for outside radii and gauge pins for inside radii.
  13. #12
    Sep 2018
    Michigan
    177
    33
    94
    Does the tooth profile on the belt change shape? Or does it pivot similar to the way a traditional drive chain does?
    I was thinking it would pivot like a chain, making it possible to solve for any pully tooth profile via iterative subtraction/slicing.
  14. #13
    May 2002
    South Central PA
    14,667
    2874
    4400
    Quote Originally Posted by jcorsico View Post
    I understand that. Just FWIW we've been violating most of those those recommendations for years, and with higher loads and higher RPM than Gates says those belts will tolerate. I'm pretty sure they come up with slight changes to the tooth shape just to make the older out of patent belts technically obsolete in the catalog
    The belts run on the major diameter of the pulley, not the tooth space, the tip of the tooth is most important, as you mentioned the body of the belt does not ride in the bottom of the tooth space and there is daylight between them under load. Get an 8mm GT2 belt and wrap it around an HTD pulley and see how it fits.
  15. #14
    May 2002
    South Central PA
    14,667
    2874
    4400
    No, it changes shape for every tooth count, that's one of the things that make HTD/polychain/polygrip belts difficult.
  16. #15
    Jul 2006
    14,285
    3128
    9507
    Yeah, like Mud said. Also, the "last bit" of tooth design gives you a little quieter running, a longer run life, etc., but you can get away with approximations if you're careful and don't mind the small performance hit.
  17. #16
    Sep 2018
    Michigan
    177
    33
    94
    Sorry to bump this thread but I am still a kind of confused, probably in part because my post wasn't very clear.
    When I say iterative slicing I was thinking something along the lines of a motion sim, like a frame by frame of how a hob cutter would take a chip. In theory it should return a very close representation of the involute of any shape you feed into it.
    Wouldn't this work to generate the correct profile or something close to it?
  18. #17
    Apr 2018
    9,729
    4680
    Technical name 'odontograph' and yes it would work, that's how they used to design hobs on paper, but what software did you use ? Pretty.
    (Looks a lot like Cadkey 7 from here )
  19. #18
    Sep 2018
    Michigan
    177
    33
    94
    Quote Originally Posted by EmanuelGoldstein View Post
    Acad 2d - Mostly automated via a lisp routine I was working on for standard involute gears.
  20. #19
    Jul 2006
    14,285
    3128
    9507
    Maybe. Putting my "not an engineer" cap on, the method shown seems to prioritize the root of the sprocket, which to my mind is not the critical feature to design around. It's flank engagement/disengagement.
    If you can rerun the process looking at that it might be more useful. Whatever gets you full flank mating as quickly and smoothly (minimize rubbing) as possible will to my mind be most effective.
    Leaving a gap at the root may also help with reducing the noise of trapped air being squished out.
    Again, not an engineer. If there are some floating about to yay or nay my thoughts that would be welcome.
  21. #20
    Apr 2018
    9,729
    4680
    What he did will show how an imaginary perfect rack (belt) will mesh with an imaginary perfect sprocket. That's the start point. Modifications come next, if you want to make any.
