Nickysticks67
- Oct 17, 2018
For 6 months I've been lead programmer and operator for a glass company. We have 2 haas vf4ss and 2 mini mills. Since I took over I have revamped the department with machine able vises, using their opm40 probes to their fullest rather than just an edgefinder like they have been. And I've reduced cycle times to the best of my ability by researching new tooling and program methods. I am in need of advice from someone with knowledge of the glass industry. I utilize "stepover methods" only .010 at a time at most. with 120 – 600 grit bits ranging from .020 dia to 1.5 inch diameter, some solid abrasive tools, core drills for plunging, ramping in, and helical entries either to get another tool to finish the profile with side cutting since I have not found bits for glass that will cut downward as well as side or stepover movements besides core drills but those are limited to their small cutting depths and their need for cleaning and dressing too often. For milling and edge grinding borofloat, fused silica, flashed opal, b270 and Uv filters I've been using these diamond grit end mills called CeraX endmills. I am in dire need of someone with experience with these materials as there isnt much on the web as far as advice on toolpaths, feeds and speeds (hands on learning) workholding is typically pine wax and ground aluminum bases, or vacuum which we are in need of reliable and modular vacuum fixtures , all we have are what weve made in shop. Which only work 50% of the time and being only one person with 4 machines I'd rather convince them to invest in products rather have me fashion them all. Does anyone have any recommendations regarding abrasive tooling with plunging and edging capabilities, workholding, and toolpath/ programming advice. any articles, Websites, forum posts. any and all info helps. Thanks for listening to my convoluted cry for help.
