Mike1974
- Nov 5, 2014
- Tampa area
So I have very little exp with stainless, not to mention hardened stainless. Anyone with experience care to share feeds/speeds? Will be milling and drilling and tapping. I think the setup will be rigid, machine is a new Mazak.
I'm looking at HSMadvisor for a face milling op and it seems very slow to me.
Not sure how to make that bigger, but the numbers are .120 doc (question about that to follow) 311 rpm, 5.71 ipm, ,0045 ipt with a 50mm insert face mill. This has the speed and feed slider at a tad over 100% and tool life at 78%. If I crank the sliders to 150% I get 434 rpm, 11.07 ipm, .0063 ipt and tool life down to 32%. Do these numbers sound right? At these numbers that is only 224sfm which seems low to me, but like I said no exp with this stuff.
Also, Sandvik recommends light depth of cut and fast feed for face mills, here about half way down the page https://www.sandvik.coromant.com/en...erials/milling_hard_steels/pages/default.aspx
I know on trochoidal(?) milling that is right, but does that sound right for a face mill? I will be doing an approximate 80% stepover. Can I take .12" doc like that, or should I split that?
How about solid carbide end mills? Still in the 200-300 sfm range, or..?
thanks for any help
thanks for any help
