rokstarr999
- Feb 7, 2014
- Sonoma County, USA
I have a rush job starting Monday. I have some thin 17-4 SST parts to do. The geometry isn't all that complicated, but the part is thin with a couple semi-tight tolerances.
The Jist..
1.5" dia x .062 w/ .002 flatness.
.o62 and .0645 hole with +/- .0002
.o65 x .625 slot w / 45 deg x .040 chamfer all the way around the slot.
This is what I'm thinking so far.
1.) .063 ground plate.
2.) rough Water jet blanks. finish OD and chamfer both sides.
3.) heat treat
4.) machine slot
5.) drill and ream holes
The diameter is small so I'm hoping it will maintain flatness after heat treat. I ordered cobalt reamers thinking carbide might be too brittle at this diameter.
Any tips on sfm and chip load on a .030 4FL EM and for the reamers would be helpful.
Thanks in a Advance.
The Jist..
3.) heat treat
4.) machine slot
