Subsituting material isn't an option. I am 3'rd down on the chain of contractors, the material was already bought, the engineers involved don't take as kindly to suggestion as they might. Other customers are better tuned to changes.
I machine many hundreds of punds of Delrin at a time. It realy is nice stuff to work on, except if you push too hard, too much rpm and feedrate it outgasses something unfriendly, and will give you a whopper of a sore throat. Of course that is from leaning into an enclosed machining center that is producing a few hundred punds of chips in very short time, so it does get concentrated in there.
I got the nylon prototypes done, they were in a hurry, then they were called out of town, so the approval for the remainder of the production was delayed...
We will run the production starting Monday morning now. Sunday I will try to get a better part by taking some of the suggestions.
Thanks for all the great suggestions so far!
Holding the +- .002" has not been a problem yet, surprisingly... However, once it leaves the shop, and gets dry or moist it is anybodys guess what will happen to it.... Turns out the holes with the tolerance are only clearance holes for plastic push in rivets!. (shakes head and mumbles)
I sure don't have any problem with this post drifting off to other plastics. The more discussion the better.
I've worked with teflon before. Now there is a plastic to work with! Surprisingly dense, and $$$.
Makes nice looking parts.
One part I had to make for an electronics company was out of Delrin, I had to hold +- .0002" on a part about 2" square. Delrin worked Ok for that...
Other jobs with acetal and the material had a lot of stress built in to it. Shaving off one face to get it to thickness on a 7" X 9" X .75" part and it would curl like a potato chip.. I didn't specify stress releived material. My mistake.
The curl was about .007" of curve over the part.
Worked on Durapol for electronic wave soldering once.. That stuff is pretty abrasive, the shop that sent it to me used carbide burrs instead of cutters to cut it.
Pete
(edit, I spelled Potato as if I were Dan Quail)
[ 07-17-2005, 02:03 AM: Message edited by: 3t3d ]
