Bulletsnatch
- Feb 20, 2021
Hello all I'm new to the forum and my name is Jon. Im only a few years into the industry and work at a training aerospace shop. We don't have engineers. I turn a lot of heat treated 7075 aluminum and a lot of aluminum nickel bronze. The reason I am here is because no one at work has an answer to my problem. Every time I turn a ring style part with a diameter over 3 inches, it springs inconsistently once you unclamp the workpiece. I'm currently trying to bore out a ring with an OD of 3.750" and an ID of 3.250" and an OAL of .530". The material is 630 Aluminum Nickel Bronze AMS 4640. My clamping pressure is 100lbs. It starts out as a .600" thick slug of 3.760" diameter material. I face it and turn half the OD, flip it and face and turn the other half while only clamping onto .200" of the length of the part. Run-out to the jaws is within .0003". Then I insert drill a 1.750" hole, take it out to remove the slug left by the drill, and re-indicate the part back in. Then boring out the ID from 1.750" to 3.250" I tried to take passes with a .050" Depth of cut per side. Then I tried .025" per side passes. Still after unclamping, the part springs inconsistently from part to part. Some parts will be .001" out of round and some will only be .0003" out of round. Without programing a U taper move the part cones out about .001"-.002" larger on the clamped side of the part. But it doesn't repeat within that difference. I have to leave material on the ID, take the part out and measure it's unique taper, and adjust my U move accordingly from part to part. My boss wants me to get this part running on a production level and I'm stuck. Does anyone have experience making larger diameter rings? Every time I bore rings out of high tensile aluminum they spring inconsistently within a .002" margin. My tolerance is usually + or - .001" but I like to keep it a lot tighter than that. Any ideas or suggestions would be appreciated. Thanks God bless.
