Macro B Adjusting Work Offset Program Help
Results 1 to 16 of 16
    Oct 2019
    Illinois
    16
    7
    Default Macro B Adjusting Work Offset Program Help
    Thank you for taking some time to try and help.
    I am running a Romi M27 Lathe, it has a GE Fanuc Series 21i-TB controller.
    We are running tube stock, cutting 6 parts from the length sticking out of the chuck, then advancing the tube to do it again.
    The program I was given to use runs a single part, has the user adjust the work offset, runs a single part, has the user adjust the work offset, etc.
    I am tryin to use Macro B to get the programming to adjust the work offset after each part, for 6 parts, then set its self back out to the very first starting work offset.
    I use the part counter to set when the program should change the work offset.
    I've successfully wrote and ran another program using the part counter in a similar fashion, so that part should be pretty solid.
    Currently I am getting a G code alarm, 010 Improper G-Code.
    I'll indicate in my program example where the machine stops running the program and pops the alarm at.
    The code that I have come up with is as follows:
    IF[#3902GT6]THEN#3902=6
    IF[#3902LT6]THEN#3902=6
    IF[#3901GT#3902]THEN#3901=0
    #3901=#3901
    IF[#3901EQ0]GOTO20
    IF[#3901GE1]GOTO10
    N10 G90 G10 L2 P1 Z0.0 (This is the line that the machine alarms out at)
    N20 (FACE PART)
    T0202
    G40 G80 G90 G95 G97
    G0 Z0.2
    X7.9
    M3 S300
    G1 Z0.0 F0.025
    X6.0
    G0 Z0.1
    M5
    X18.0
    Z-1.0
    M00
    IF[#3901LE5]GOTO40
    IF[#3901EQ6]GOTO30
    N30 G90 G10 L2 P1 Z0.0
    N40
    M30
    The first time I run the program it works fine, since the indicated line is skipped.
    It's not until the second run through that it alarms out for me.
    The book I am using explaining and teaching Macro B programming told me to use those codes for the input.
    Where G10 is Data Setting, L2 is Work Coordinate Setting, and P1 tells it to set G54.
    It seems like it should work, but something is off. I use the same exact codes the book gives me, so I don't know. I have even tried variations of the L & P, like L0002 & P0001, that didn't work. I have to guess its something dumb with Fanuc where it doesn't know what those codes are or something. It acts like G10 is not a valid code for Data Setting.
    The book that the company has that I got the information from is called: Fanuc CNC Custom Macros by Peter Smid.
    Any help would be greatly appreciated.
    Thank you very much.
    Have a great day.
    Sep 2010
    Victoria Australia
    4,137
    1756
    Hello RevHaus,
    The full title of the alarm you're getting is a p/s 010 alarm and simply means that the G Code that has raised the alarm is unusable with your control; your control doesn't have that option.
    Even if your control had the G10 option, the better method, in my opinion, is to write directly to the System Variable for workpiece zero point offset values. System Variables #5221 to #5224 respectively are for the first to fourth axis, G54 workpiece zero point offset value. As you have the User Macro option with your control, that method is available to you.
    Regards,
    Bill
  3. Likes DouglasJRizzo liked this post
    Dec 2013
    Louisville, KY
    14
    I see a few points to look at here.
    Try moving your N10 above your G10 line.
    Also it looks to me like you may be more of a mill guy than a lathe guy?
    If that’s really a lathe control, G90 isn’t used for absolute/incremental. Fanuc lathes use U and W for incremental, X and Z are absolute. Also G95 is per rev on a mill but a lathe is G99.
    I suspect the improper G code is due to the G90.
    Sep 2010
    Victoria Australia
    4,137
    1756
    Quote Originally Posted by mmeredith0015 View Post
    You may be right, but it would depend on the G Code System, A, B, or C, that is set via parameters for the OP's control. For G90 to be the issue, G Code System A would have to be set. In that case a p/s 010 would be raised by G95 in the G40 G80 G90 G95 G97 Block. The OP says that the program works fine for the first execution; accordingly, the program must have executed the G40 G80 G90 G95 G97 Block without issue.
    To RevHaus
    In your following logic, the IF[#3901GE1]GOTO10 is superfluous
    IF[#3901EQ0]GOTO20
    IF[#3901GE1]GOTO10
    and the same goes for IF[#3901EQ6]GOTO30 in the following:
    IF[#3901LE5]GOTO40
    IF[#3901EQ6]GOTO30
    In each case, if the conditional statements IF[#3901EQ0]GOTO20 and IF[#3901EQ6]GOTO30 don't test true, the program will step onto the next Block and whether that conditional statement tests true or not, the Block following it will be executed; you have no alternate strategy for IF[#3901GE1]GOTO10 and IF[#3901EQ6]GOTO30 not testing true.
    In each case, the following will work the same as your current program:
    IF[#3901EQ0]GOTO20
    N20 (FACE PART)
    and
    IF[#3901LE5]GOTO40
    G90 G10 L2 P1 Z0.0
    N40
    M30
    Regards,
    Bill
    Oct 2019
    RUSSIAN FEDERATION
    G54 work offset data can be obtained in #5221...#5226 values range. #5222 for Z axis, I believe. Then, we need to store original datum...
    N10 #500=#5222 (OBTAIN ORIGINAL DATUM)
    And finally we need to move it to some value...
    N20 #5222=#5222-10 (NEW VALUE FOR G54 Z)
    In place where you need to return original datum just insert...
    N30 #5222=#500 (GET ORIGINAL DATUM BACK)
    May 2007
    Massachusetts
    933
    14
    112
    Haven't used Fanuc in a while. Do you have to cancel G10 mode with a G11?
    Dec 2013
    Louisville, KY
    14
    Yes, good eye! Cancel parameter input with G11.
    OP, try moving the G90 above as well. I also typically use system variables myself but I don’t believe you can fire other commands in conjunction with the G10 line.
    It may help in this instance just to start from that line of code. Remove the N10 and G90 and see if it will take the line without issuing the improper G code alarm. This alarm isn’t related to Marco logic, it’s the syntax of the N10 line.
    Good luck!
  9. #8
    Sep 2010
    Victoria Australia
    4,137
    1756
    Yes for Programmable Parameter Entry, but not in the OP's case where Work Offsets are being changed, not parameters. G10 has more than one application. One is for use with Work and Tool Offsets, another for Programmable Parameter Entry and another if the control is equipped with Tool Life Management. Its with its use with Programmable Parameter Entry and Tool Life Management where G11 is used to execute Programmable Parameter Entry and Tool Life Management mode cancel, but definitely not required when used to edit Work and Tool Offsets.
    Programmable Parameter Entry mode is initiated by the following Block Syntax:
    G10L50
    The OP is using G10 for Workshift Offset editing; accordingly, G11 is not required.
  10. #9
    Dec 2018
    222
    563
    57
    Quote Originally Posted by beege View Post
    Only if you are changing a parameter. Anything G10 L50 blah blah blah needs a G11 to cancel after.
    G11 not needed if you are simply changing workshift or any of the work coordinate systems.
  11. #10
    Sep 2010
    Victoria Australia
    4,137
    1756
    Good luck!
    What other commands do you think are being used in conjunction with the N10 Block? If the OP's control is configured to use G Code System "B" or "C", there is zero wrong with the syntax of that block. G10 is a Group 00 G Code and G90 a Group 03 code; accordingly there is absolutely nothing wrong with combining those G codes in the one Block. There is also no problem in having a sequence number on a G10 Block.
    I suspect that the OP's control is configured to use G Code System B, in which case G90 is a legal command with the way the OP's is using it with G10. As I mentioned in an earlier Post, if the OP's control is configured to use G Code System A, which would make the use of G90 wrong in the OP's example, his program would have raised a p/s 010 alarm for the use of G95 in the G40 G80 G90 G95 G97 Block, as there is no G95 in G Code System A.
    G90 is an included G Code in all three G Code Systems (A,B and C), but for different uses in System A and B/C. Therefore, irrespective of the G Code System the control is configured to, G90 would not raise a p/s 010, but other p/s alarms would be raised if G90 were to be used as in the OP's program and his control was configured to use G Code System A.
  12. #11
    Jan 2019
    Missouri
    419
    107
    104
    Not to hijack
    but
    Why cant I write to #7021 and above if I can read from #7001 through 8. Yields alarm 115.
    18i M maybe model B. Its around a ~98-99
    work around is G10L20P3 Y#7002
  13. #12
    Sep 2010
    india
    1,376
    75
    263
    Maybe only one additional WCS is available/purchased.
  14. #13
    Oct 2019
    Illinois
    16
    7
    I did start out working mills.
    That being said, aside from where the error in the code shows up, the G90 and G95 codes work fine as written. That is the standard safety line that I was given to use in my programming and it never pops any alarms, and it always works. We occasionally swap incremental for absolute and back again, and the code works just fine the way I have it.
    I do absolutely appreciate your help though. I will try some of the things that you pointed out though.
  15. #14
    Oct 2019
    Illinois
    16
    7
    Thank you.
    I will try this and see if I can get it to work.
  16. #15
    Oct 2019
    Illinois
    16
    7
    Thank you.
    I will work with this and see if I can get the program to work.
  17. #16
    Oct 2019
    Illinois
    16
    7
    Thanks for the help.
    I'll see if this helps make the program work.
    I will share my end results if I get it running, or if I move the error to a different line. haha
