Hi guys. I’m the setter of a Nexturn SA-20d with and 18i-tb controller.
I’m working to solve a top cut issue. We are using a G3000 to do a cut off function at the start of the program.
We call the G3000 and it references O9019 and does a check for the machines position to know if it needs to run a top cut or go directly to machining and skip the cutoff.
I want to solve the issue but can’t access O9019 macro to see why it always fails the check essentially double top cutting every single part.
Parameter 3202 is unlocked.
Any help would be greatly appreciated.
