dandrummerman21
Stainless
- Feb 5, 2008
- MI, USA
Kitamura H400 (1998)
The machine came with tombstones (yay), but they are simply too big, at 10" per face.
The only problem with this machine is that you are limited in the swing you can put on B.
While a 10" face is fine for mounting fixtures to, it doesn't allow me to put on vises. I would clear the pallet change door by about 1/2" with a vise on each side. Put anything in the jaws and boom.
So I want to make new tombstones. We picked up some used pallets off of ebay for pretty cheap (450$ each), but tombstones that size are hard to come by. 400mm pallet with 6" column, 22-24" total height. I plan on mounting 4 BL6 Chick vises (6 inch vises) to each tombstone.
So, looked at material options. all options are roughly 1000$ material for 2 tombstones (base and column):
6 1/4" 6061
6.030" Durabar milled
6 1/4" Durabar cast
Originally I wanted to get steel, so I could bolt the column to the base and have it welded after, but I don't see 6"+ square readily available...
So my pros and cons for aluminum:
+weldable
+lightweight
+easy to machine
-softer
-lightweight (won't dampen as well, less mass)
-easier to strip out holes
-worse for bolting something direct to the face
For cast iron:
+heavier (dampening)
-can't weld it (can braze it though?
I honestly think the iron would be better, but worry about loosening up over time (I would dowel it and put a bunch of bolts in the bottom though). I don't like the aluminum but I could bolt it and weld it and it won't be a problem in that regard.
I will have about 600lbs+ of vises on it...
What do you think?
6 1/4" 6061
6 1/4" Durabar cast
+weldable
+lightweight
+easy to machine
-softer
For cast iron:
What do you think?
