Nerdlinger
Stainless
- Aug 10, 2013
- Chicago, IL
We use spring-loaded collet stops in the sub spindle (collet) to pop the part out when the collet opens. From time to time parts do not pop out and then you can guess what happens when the sub goes to pick off the next part...
I imagine there is a way to sense if the part is there or not, maybe with some sort of....sensor...., but I am not sure if there is a way to input that signal into an....input....and then reference the state of that input in the program. I know it has macros enabled so I'm looking to do something like:
IF{DI7EQ1]GOTO100;
Or maybe an MFIN deal?
Does anyone know how to do this or if it even can be done on that machine/control??
Thank you!
IF{DI7EQ1]GOTO100;
Thank you!
