Matsuura MC-760VX, Yasnac MX3 Serial Communications problems
Results 1 to 12 of 12
    Apr 2015
    New Mexico
    151
    7
    8
    Default Matsuura MC-760VX, Yasnac MX3 Serial Communications problems
    Hello,
    This is an extension of a previous trouble shooting on this machine.
    I have got to the point where I am working on the communications to/from the Machine.
    I have a laptop and have loaded Cadems NCLite DNC software
    I have looked at the registers in the Matsuura to verify stop bits and baud rate and played with data bits.
    The machine is setup only to use the 2nd RS232 port (doesn't seem to be an issue that I can tell) the 1st port is not enabled.
    One thing I have not changed is the length of the RS232 cable...it maybe close to 30ft. The previous owner was using it so I haven't messed with it...but possibly an issue.
    I have attached pictures of the machine port settings, the DNC software setting and the file received FROM the matsuura
    Per a suggestion from other posts, I worked on getting the data out of the matsuura in the correct format, the picture attached is the output registers from the Matsuura.
    Using the same settings I attempt to send a file to Matsuura. I get an error 077 which states '10 characters or more were read after stop code was issued'
    It seems the machine and laptop arn't talking quite correctly.
    I tried changing the hand shake method but on other settings it did not seem to work at all.
    Any thoughts as to why I would be able to receive a file that looks correct but not be able to send one to the machine?
    I have also attached the page from the manual that describes the parameter settings for the MX3. Maybe i am reading it wrong as well.
    David
    Sep 2010
    Victoria Australia
    3,192
    1251
    Quote Originally Posted by Cooperstock View Post
    Hello,
    Hello David,
    As you have parameters set for 4800 baud rate, you can use a cable, having a capacitance of 50 pF/ft, up to 1000ft long. Accordingly, your 30ft long cable is definitely not an issue.
    You have parameter bits associated with the use of Control Characters (DC1 to DC4) set to Not Use (Xon = DC1 – Xoff = DC3); these are Software Handshake characters. Therefore, unless you’re using a cable configured for Hardware Handshaking and the Comms Software set to use RTS/CTS (Hardware Handshaking), which from your attached pictures it appears not, then these settings will cause the error 077.
    Regards,
    Bill
    Apr 2015
    New Mexico
    151
    7
    8
    Quote Originally Posted by angelw View Post
    Hello David,
    Regards,
    Bill
    Hi Bill,
    Thank you for your reply, I am still trying to understand what it means for my settings.
    What I am understanding is the following
    1. cable length (assuming the capacitance) shouldn't be an issue
    2. the Serial connector has to be wired for hardware hand shaking, so I may need to change the wiring...or I need to set the communications settings to go with the way the connector is wired.
    3. Im not sure where you are seeing the control character (DC1 to DC4) settings. From the PDF page it looks like D5 in 6026 and 6028 are the "Control code sending command", and when set to 1 it does not send the control code. I don't know how to interpret this text related to what type of handshake it needs.
    I do know this machine has been used before, So I am not certain I need to rewire for it to work. But I am willing to rewire the connection if needed. I would rather do it right, then 'make it work' if it wasn't correct before.
    Thank you again for your input, I do appreciate having some direction.
    David
    Sep 2010
    Victoria Australia
    3,192
    1251
    Hi Bill,
    David
    Hello David,
    To determine the pin out configuration of your cable (the cable between the control and your computer), remove the back shells from both ends, but at least from the DB25 Male Connector at the control end of the cable and note the wires that are attached and any pins that are bridged. The configuration for Xon/Xoff Handshaking (Software Handshaking) will be as follows:
    Machine Side ---------------------------------- PC Side
    DB25 Male Connector -------------------- DB9 Female Connector
    1 -- Shield Trace ------------------------ Not Connected
    2 ---------------------------------------------- 2
    3 ---------------------------------------------- 3
    | Bridged
    5
    6
    8 All Bridged
    20
    7 ---------------------------------------------- 5
    If your cable is configured as above, then the control and Comms Software should be set to used Xon/Xoff Handshaking
    Whether Control Characters are used (characters for Xon/Xoff Handshaking) is set with bit 5 of parameters 6026-6027 and 6028-6029, depending on the Ports at the control being used. According to the pictures you attached to your earlier Post, these are set to Not Use these characters, but your Comms Software is set for Software (Xon/Xoff) Handshaking. Therefore, the Uart of your computer will be primed to use Xon/Xoff to control the flow of data, but because your control is set to Not Use these characters, this data flow control will never happen.
    Regards,
    Bill
  5. Likes Cooperstock liked this post
    Apr 2015
    New Mexico
    151
    7
    8
    Hello David,
    | Bridged
    5
    6
    8 All Bridged
    20
    Regards,
    Bill
    Hi Bill,
    Thank you for the additional details. I will look at the connectors now to check wiring.
    I can also try changing bit 5 of the appropriate serial port to use the flow control and see if that corrects the transmission.
    Why does the data flow work from the machine to the PC with the settings? Is the PC more lenient about settings? Seems like it should be a two way street.
    Thanks again
    Dave
    Sep 2010
    Victoria Australia
    3,192
    1251
    Hi Bill,
    Thanks again
    Dave
    Hello Dave,
    In really rough terms, when the Transmit/Receive Buffer becomes sufficiently Full or Empty a signal is sent (or received) by way of either a Control Character on the Transmit Lines, or Variation of Voltage on Control Lines. When sending data to the control, the control will send an Xoff (DC3 - Ascii 19) to tell the Sending Device to stop sending. Once enough data has been moved from the Buffer to storage, an Xon (DC1 - Ascii 17) is sent to the Sending Device to start sending again. This Handshaking continues until the end of the file being sent is reached.
    If the rate the data is being sent is sufficiently slow that the data in the Buffer is always moved to storage before the threshold for sending an Xoff is reached, then in theory, no handshaking at all is necessary. The size of the Transmit/Receive Buffer of the PC is probably greater than that of the MX3 and the PC Hardware more efficient
    Regards,
    Bill
    Sep 2013
    Minnesota
    205
    38
    37
    ...One thing I have not changed is the length of the RS232 cable...it maybe close to 30ft. The previous owner was using it so I haven't messed with it...but possibly an issue.
    Many people overlook the condition of the cable. Make sure it has zero pinches or kinks in it and take a good look at the ends for damage as well. If it is a custom made cable then take a really good look at the ends. (most people aren't nearly conscientious enough to make cables IMO) Watch where you are running your cable to keep away from high voltage and high RF noise sources. I've been told to make some loops of cable at each end to help keep noise down. We had one cable run that was super long but had much a higher baud rate than one of our short (twenty foot perhaps) cable that had to be in a high voltage/noisy RF area. Don't assume that because the cable worked before it will work in a different installation.
    I recommend if you suspect any issues with it at all then don't hesitate to replace it and don't buy a cheap cable either. A loooong time ago we contracted a company to do some serial cable runs for us and we assumed they new what they were dong. It turned out they used the wrong spec cable and we ended up fighting all their cable.
    If you really want to stay with a long serial cable and need to replace the one you have, I recommend a Grizzly cabling. It is by far the best I have used for rs232 applications because it is extremely resistant to interference and it uses slick, RJ45 ends. When you buy a cable you tell them what machine it's for and which flow control you're using and they supply the proper connectors which attach to the RJ45 connectors. They are multi shielded and claim to reliably run up to 300'.
    Also, don't be hesitant to buy a lan cnc device if it suits your needs. You will rid yourself of long serial cables and have much more capability such as adding gigabytes of storage.
  9. #8
    Sep 2010
    Victoria Australia
    3,192
    1251
    Quote Originally Posted by Qwan View Post
    RJ45, really? Using as cable with RJ45 connectors simply introduces additional connectors and potential for further connector issues; at some point the RJ45 must interface with a DB connector to connect to the control and computer.
    The standard has a clear answer to the maximum cable length. At a baud rate of 19200, the maximum cable length is 50 feet, or the cable length equal to a capacitance of 2500 pF. Accordingly a cable having a 50pF/ft capacitance is used in the standard. If for example UTP CAT-5 cable is used with a typical capacitance of 17 pF/ft, the maximum allowed cable length is 147 feet (for the max baud rate of 19200). If speed is reduced by a factor 2 or 4, the maximum length increases dramatically. The OP has the control and Comms Software set to 4800 baud. Accordingly, a 50pF/ft capacitance cable, up to 1000ft, could be used. Therefore, 300ft is rather irrelevant and 30ft infinitesimal.
    Many simply hang their hat on the term "Null Modem" cable, not understanding that Null Modem is a generic term and refers to any cable where the Transmit/Receive lines are swapped end for end.
    Often I've been called to resolve communication issues between CNC controls and PC, where the client swears black and blue that the cable is not the issue, because they bought an off the shelf Null Modem cable from a reputable supplier, only to find that the cable has no facility for Handshaking (either via the cable being a Loop-back Handshake Null Modem, or Full Handshake Null Modem Cable). Accordingly, I treat all cables bought off the shelf as being incorrect and make my own.
    Assuming the OP's cable is configured as a Loop-back Null Modem cable, the control characters (DC1 and DC3) are transmitted on the same lines as the data being sent. His issue has been an Over-run error, not that no data at all is being transmitted, which would be more the case with a data line severed due to it being crimped.
    The pictures the OP attached to his first Post clearly indicates that he has the Handshaking Methods between the control and the Comms Software mismatched; Hardware Handshaking at the control and Software Handshaking at the Comms Software.
  10. #9
    Apr 2015
    New Mexico
    151
    7
    8
    Thank you guys for the input. I had decided to remake the cable. The PC side had Pins 7 and 8 jumpered. and on the Machine side pin 1 was not grounded/connected to the shield.
    Not sure if it matters, but it appears a 15 wire cable is used, it appears to be a shielded 'serial' cable. I didn't see an issue with continuing to use that.
    I have attached the pin connection as stated in the Yasnac MX3 manual. I had read in a couple other posts that people recommend to wire as per the Fanuc CNC serial cable. I found a diagram of this cable and its odd that it does NOT swap the TX and RX lines from the computer to the machine, is this a mistake?
    It seems I should follow the MX3 wiring instructions although I would be glad to hear recommendations.
    David
  11. #10
    Sep 2010
    Victoria Australia
    3,192
    1251
    Hello David,
    The cable you have and Posted pictures of in your last Post, is a Loop-back Handshaking, Null Modem (Xon - Xoff (Software Handshaking))Cable and is the same as the pin-out shown in my Post #5 with the addition of CTS (pin8) and RTS (pin7) bridged at the PC End. The bridging of CTS - RTS is not necessary at the PC end, but it will cause no trouble (leave as is).
    The cable for the configuration you currently have requires no more than three wires. When making a Loop-back Handshaking cable, I use a cable with the minimum number of wires (but at least 3 of course), with a Shield trace wire.
    The Shield Trace wire should only be connected at one end, preferably at the Control End. Connecting the Shield Trace wire at both ends can result in a Ground Loop when the two devices don't share a common Earth, or if the Earth for either, or both is not good.
    As I have said a few times in this Thread, judging from the pictures attached in your first Post, the most obvious cause of your Over-run issue is that you have the Handshake Method set unmatched between the Control and the PC Software. Your pictures show the Control parameters to be set to NOT USE Control Characters, hence the Control is set to Hardware Handshaking and your PC Software is set to Software Handshaking.
    With the Software Handshake cable configuration you're using (and there is no reason to not continue with this configuration, given that its worked for the previous owner), as long as you have a hole in your arse, with unmatched Handshake settings, or with both devices were set to Hardware Handshaking, you will experience grief. Resolving the hole in your arse will probably have no affect, so better to address the unmatched Handshake issue.
    The TX/RX pins of a DB9 connector is 3 and 2 respectively. The TX/RX pins of a DB26 connector is 2 and 3 respectively. Accordingly, when connecting a DB9 and DB25 connector, connecting 2 to 2 and 3 to 3, is cross connecting the TX and RX lines. When connecting two DB25 connectors, 2 to 3 and 3 to 2 is required to cross connect the TX and RX lines. Any deviation from this is a mistake.
    Regards,
    Bill
  12. #11
    Apr 2015
    New Mexico
    151
    7
    8
    Hello David,
    Regards,
    Bill
    Hi Bill, I wasn't ignoring your handshaking directions, I did try several configurations: Using the cables that came with the machine, I tired the following:
    1. Bit 5 on (no control characters) with 'software' hand shaking set on PC side (config shown in the pictures)
    2. Bit 5 on with 'Hardware' on PC side
    3. Bit 5 on with 'Both' on PC side
    4. Bit 5 on with 'none' on PC side
    for the above configurations, when trying 2,3 or 4 above the PC says it sent the g-code but the machine reports nothing (sitting there listening, no errors)
    I then set bit 5 to '0' and tried the same sequence and got the same errors.
    I do not have the same PC/laptop the previous owner had, so I do not know what software he used. I guessed it wouldn't matter as it was just serial transfer. I did try using Hyperterminal on a different laptop but that didn't have any good results, using a DNC software made it easier to change parameters.
    I plan on repeating the configuration test just to make sure everything was well connected and I didn't 'fat finger' one of the settings.
    -David
  13. #12
    Sep 2010
    Victoria Australia
    3,192
    1251
    -David
    Hello David,
    With the cable you have (a Loopback Handshake Null Modem), the only machine/PC software configuration that will work is:
    1. For the control to be set to USE DC1 to DC4 characters.
    2. For the PC Software to be set to Xon/Xoff (Software) Handshaking.
    Don't waste you time with any other setting.
    Does the PC you're using have a real Serial Port, or are you using a USB to Serial adapter?
    If you continue to have trouble, purchase an RS232 Test Plug. They are not expensive and will show what is happening on the Transfer/Receive and control lines. With regards to what will be shown for the Control Lines, because the cable is a Loopback Null Modem Cable, RTS/CTS should be seen as On all the time.
    Regards,
    Bill
