I have a 1995 Matsuura RA-IF with a Yasnac controller that I bought a couple months ago. After getting all the bugs worked out and figuring out how to work the controller and import files I had it running great but in the middle of running a program my air pressure got low while doing a tool change and I had to manually put the tool arm back into home position. Since I've done that I can't get anything to run in MDI or Tape mode. I can control everything in Handle mode with no issues but I can't do a tool change or run the spindle. The crazy thing is that I don't get any alarm codes, it just wont work. Any help to get my machine up and running again would be greatly appreciated!!
