Mazak lathe
Results 1 to 7 of 7
Thread: Mazak lathe
    Sep 2015
    ALGERIA
    8
    Default Mazak lathe
    Hydroliic oil is leaking in front of turrets is there any one had a problem before?
    Sent from my Nexus 5 using Tapatalk
    Jul 2011
    GA USA
    18
    Few more details about the year and model would be helpful. Could be several things.
    Oct 2016
    UNITED KINGDOM
    44
    5
    17
    Sep 2015
    ALGERIA
    8
    Quote Originally Posted by lx545 View Post
    Quick turn Nexus 200my.both oil and coolant is leaking specially when tool change happened.
    Thanks for feed back
    Jul 2011
    GA USA
    18
    Where is it leaking from on the turret? Since you said oil and coolant that leads me to believe its the coolant plunger that is hydraulically forced to the back face of the turret. I would start there myself.
  6. Likes Justin_Terry liked this post
    Sep 2015
    ALGERIA
    8
    The leak is in the front of the turrets box is .l opened it's plunger looks like cartidge and some of o rings are worn out piston itself brass like material is worn out .I tried to replace similar o rings and clean put back still leaks both oil and coolant when the tool change happened .l ordered new parts for now is working.
    Thank you for feed back
    Jul 2011
    GA USA
    18
    Definitely can be a wear item as its cycled every tool index. Hopefully that takes care of it.
