Mazak QT250 Fusion 640T: Spindle acceleration parameters
Likes Likes:  0
Results 1 to 4 of 4
    Nov 2021
    Wisconsin
    Default Mazak QT250 Fusion 640T: Spindle acceleration parameters
    Iím looking to reduce the load on my electrical system by reducing the spindle accel/decel times on my QT250HP. Does anyone when know what parameters need to be altered and how to do it?
    Best,
    Matt
    Dec 2012
    Se Ma USA
    2,403
    190
    1340
    Quote Originally Posted by KMatt View Post
    I’m looking to reduce the load on my electrical system by INCREASING the spindle accel/decel times on my QT250HP. Does anyone when know what parameters need to be altered and how to do it?
    Best,
    Matt
    Fixed it for you. Increase ramp time. No help om parameter though.
    Sep 2006
    Abingdon, VA
    3,878
    5083
    3950
    For the prior-generation T/M-Plus controls, the spindle accel/decel was machine parameter SP33. (Prior to that, the T/M32 control was SP19). You have to do the "1131" hidden menu trick to access the machine parameters at the control, then power control down/back up for changes to take.
    If your machine has Windows embedded, you would probably access the spindle machine parameters via that...?
    ToolCat
    Nov 2021
    Wisconsin
    Thanks Scruffy, good catch. Yes, looking to increase the times.
    ToolCat, yes the machine is Windows embedded. Iíve accessed the turret servo through the control software, but didnít know I could alter the spindle drive parameters. Iíll look through the software for more information.
    Iíll post back the solution if I figure it out, in case anyone else ever needs it.
    Best,
    Matt
