Mazak ST40N alarm.
Likes Likes:  0
Results 1 to 6 of 6
    Aug 2016
    UNITED KINGDOM
    104
    18
    30
    Default Mazak ST40N alarm.
    So had a problem last night with our ancient ST40.
    When it powers up it comes up with multiple alarms.
    T32-2 control.
    202 HYDRAULIC PRESSURE DOWN (RED)
    203 AIR PRESSURE DOWN (RED)
    303 START COND. ERR,(EXT FEED HOLD) (BLUE)
    121 OVERTRAVEL (RED)
    On the control panel I have an NC alarm and MC Alarm
    The MC alarm comes on first.
    Inside the cabinet I have E7 Alarms
    Of course there is a rush job on this machine and I can't contact Mazak till Monday.
    Anyone give me an idea to where I should start looking?
    Cheers
    May 2019
    762
    235
    334
    I'm not familiar with that machine or control but I would guess all of those alarms could be caused by an overtravel condition....did the x axis maybe drift down or is it possible any of them have tripped a limit switch? If not maybe a bad limit switch. That is where I would start looking till someone with more knowledge than me reply's.
    Aug 2016
    UNITED KINGDOM
    104
    18
    30
    Hi,
    The overtravel is a strange one as the machine was parked in it's usual place.
    The hydraulics don't fire up in the alarm condition but I will try and manually turn the X Axis leadscrew see if I can get it to move.
    I've a feeling all these alarms are caused by some other underlying fault.
    Jul 2006
    Arizona
    4,704
    18667
    4553
    Check the parameters and see if you have anything funny going on like a bunch of asterisks *** in there. The only time I ever see hydraulic pump not turn on is when the parameters get corrupted due to a low battery.
    Apr 2013
    South Australia
    443
    120
    148
    How long has the machine been sitting? If batteries have gone flat and parameters lost you may need to do a re-initialise. Check parameters as has been mentioned before anything else.
    Aug 2016
    UNITED KINGDOM
    104
    18
    30
    Parameters all seem fine.
    Breakers that drive the hydraulics etc are not pulling in.
    Just waiting for Mazak to call for when they can get an engineer out.
